Excessive noise and vibrations in cabin
Hello
I have a 2010 TSX base 4cyl auto
I have symptoms of a bad motor mount but I replaced them and there's been no improvement. I have a feeling I need transmission mounts as well, but are there any other common issues to look at before I start throwing parts at it?
Thank you
Thank you
I went ahead and ordered the hydraulic trans mount (upper.) The noise and vibes reminds me of my 8th gen civic when the front hydraulic motor mount went bad. I used aftermarket for that as well and it made a world of difference. Hopefully this fixes my issue. I'll also check the exhaust hangers when I get it up on jacks or ramps.
Will update when I install it. In the meantime if anyone has any other suggestions I'd love to hear them, in case this doesn't resolve it, but I will probably just take it to my mechanic to diagnose before throwing any more parts at it.
Hello, I recently purchased a 2010 tsx and it has a heavy vibration when switched to Drive from park. Did the oem mounts fix your issue? Cause if so I need to take my to get that fixed it’s a really bad vibration.
