TSX V6 3.5L Engine mount replacement
Old Mar 9, 2018 | 05:39 AM
Alex Unimos's Avatar
I'm looking for aftermarket engine mount for a 2010 TSX v6 with no luck. OEM part number:
Front engine mount: Part Number: 50830-TP1-A01
If this part does not have aftermarket equivalence would it be possible to use Acura TL 3.5 AT or Honda Accord 3.5 AT mounts instead? The part look very similar (same J35 engine in these cars) but I can't be certain without buying first because of the Bolt and hight configuration. Has anyone had this issue or knows how to resolve this?
Old Mar 9, 2018 | 11:15 AM
jzhu625's Avatar
why OEM mount cost $500???
Old Mar 9, 2018 | 05:03 PM
Every part shop I've been to they've asked the same. Most of the time they can't even order the part because it says out of stock. I found 2 places that can order the OEM part one for $550 & another for around $800. I found an Accord mount for $70 and a TL mount for $120. They look very similar but I need to have my mechanic pull the front mount so I can side by side compare with a TL and an Accord mount. Has anyone seen these parts or knows what the difference is? I know the TSX front mount has the hydraulic pressure valve at the bottom in the same place as the others.
Old Mar 14, 2018 | 07:44 PM
Would the mounts for a 2008-2012 Accord work? https://en.m.wikipedia.org/wiki/Honda_Accord they seem to be the same car. I found that the aftermarket parts for this accord look the same as the TSX parts bit the OEM part do not fit. Any advise ?
bdtl
Jun 12, 2016 07:52 PM
dasuddith33
2G CL Problems & Fixes
Nov 20, 2008 12:08 PM
randomwalk101
Feb 8, 2008 07:56 AM
Trojanman750
May 16, 2006 12:31 PM
