rear engine mount replacement
Old Feb 7, 2008 | 10:54 PM
randomwalk101's Avatar
Anyone replaced the rear engine mount by themself? What parts will you have to remove to get to it? Approx how long does it whole process takes? Thx.
Old Feb 8, 2008 | 07:56 AM
fsttyms1's Avatar
Its an above and below the car exercise. Shouldn't take more than 2 hrs for a first timer. Get a blanket and lay on top of the motor. You will see the main mounting bolt for the motor, you will remove the nut. Then remove the 4 mounting bolts for the mount itself. (you will probably need an assortment of extensions) then place a board on top of your floor jack and lift the motor off of the mount. You should be able to slide it out now. (some have found it easier to remove the mount bracket from the motor itself to give more clearance pulling it out
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
drone619
Jan 26, 2016 07:09 PM
wilztlxs
Dec 1, 2015 09:16 AM
iCrap
Sep 11, 2015 06:21 PM
