S mode question on V6?
Old Mar 31, 2011 | 03:32 PM
sgfitzs's Avatar
On page 375 of the owner's manual, it says that when in S mode (not using paddle shifters) that the transmission should shift up to 4th. Mine only shifts to 3rd. I'm sure since if I tap the up paddle shifter, the revs drop and the indicator hen says 4. Has anyone notice this? I'm hoping that the manual is wrong or it's just a software problem. A major transmission problem with only 8k on the odo would really suck.
Thanks, Sean
Old Mar 31, 2011 | 06:35 PM
its rayden's Avatar
what speed were you driving at when you did this?
Old Mar 31, 2011 | 11:07 PM
MrOtocinclus's Avatar
On my '09 I4 this is normal behavior. When I floor it to get on the freeway in S, it stays in 3rd until I tap the paddle, and then it moves to 4th.
I checked out the 2011 I4 manual and it does state that S shifts into 4th, but only at "high speeds". So, perhaps you were not traveling fast enough when this happened.
Old Mar 31, 2011 | 11:16 PM
KillerG's Avatar
Op is too busy to care
yes, 3rd has a very high gearing, itll take you near 90, 4th is pretty massive too, but 3 is sweet spot
Old Apr 1, 2011 | 09:54 PM
SAMNYC tsx V6's Avatar
3rd limits at 110 mph in S Mode
Old Apr 2, 2011 | 08:18 AM
its rayden's Avatar
geeze.. that's insane and highly fuel inefficient.
Old Jan 3, 2012 | 08:13 PM
musty hustla's Avatar
Does S mode make the gas pedal more sensitive?
Old Jan 3, 2012 | 10:19 PM
ed_423's Avatar
SeeYou2Crew #2
^ i dont think so
Old Jan 4, 2012 | 01:34 AM
PyroDave's Avatar
probably not, just hold the gear longer, so you can rev higher and stay in the sweet spot longer
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
joflewbyu2
Oct 8, 2015 11:16 AM
navtool.com
Sep 25, 2015 05:15 PM
