Leak from A-pillar/headliner connection
Old Dec 14, 2013 | 11:16 AM
JR_Rider's Avatar
I've had a leak coming in from the area around where the A-pillar and headliner meet. I had both updates done by my dealer for the sunroom trim and windshield trim. I had the dealer bring in their water specialist and he said that a body seam had separated around that same location and was causing the leak. I had it repaired but was just wondering if anybody else had this issue before.
Old Dec 14, 2013 | 01:35 PM
robpp's Avatar
Graphite Ghost
There is someone where the roof looks like its falling in.
Dont remember exact cause but was some type of failure.
Old Dec 14, 2013 | 02:06 PM
Simba91102's Avatar
Old Guy
It's kind of early, but it sounds like a sunroof drain to me. I had water showing there (among other places) in my 05, and it turned out to be clogged sunroof drains.
Old Dec 17, 2013 | 12:50 AM
Roman Samoilich's Avatar
8th Gear
i took my head liner out. im working on my car right now after a wreck.
But those lines are not in the best of condition and location to drain. if water does get in or dirt it can sit in the middle of the liner and clog it self.
its not angled down enough to drain properly
now if the re sealed it and the seal came off. they glued it wrong or expired glue(yes that can happen) or they didnt rough up the surface before doing the job
Old Dec 17, 2013 | 11:08 AM
its rayden's Avatar
i heard one way dealers fix this issue is to use their air compressor to shoot air into the lines, blowing the dirt out.
Old Dec 17, 2013 | 12:28 PM
8th Gear
i would do the same close the trunk and just grab a air hose open moon roof up and clean it out maybe with a little water down
Old Jul 2, 2015 | 10:31 AM
kostantinos's Avatar
i just had a windshield replaced and i'm getting water stains on the headliner
I'm not sure if its from the windshield replacement, or because I removed the roof rails(wagon) or if the sunroof is clogged
where do stains show up on either scenario?
Old Jul 2, 2015 | 11:42 AM
soupi's Avatar
my sunroof was clogged and the stains appeared see post #1.
https://acurazine.com/forums/problem...eaking-927650/
Did you end up cleaning the dry water stains, if so what did you use?
Old Jul 2, 2015 | 11:58 AM
poland spring lemon sparkling water with a terry towel
took the stains out
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
