AC/ Heater Fan
AC/ Heater Fan
Everything has been great on my 2010 TSX. Then this morning there is no fan with the heater. I cant even tell if there is heat to blow. Tried auto and manual adjustments with no results. The display is working fine and shows that the fan is turned up. Just no air coming out. I checked the AC fuse and the heater motor fuse and also a sub fan fuse. All seemed to be fine.
Any ideas on what I should check next? I am hoping there is an easy fix somewhere.
thanks!!!!
thanks!!!!
