2012 TSX won't start
Old Aug 25, 2012 | 10:55 AM
tsxchick123's Avatar
Hi,
Been reading a bunch of other forums and i thought I'd join this site since it seems like there are a lot of knowledgeable people on here and hopefully I can get some answers and learn more on my tsx
So,my car won't start at all. It's a 2012 tsx tech package and it seems like the immobilizer killed my car. Nothing turns on when I turn the key to ll and lll position.No lights turn on and none of my keys locks or unlocks the doors.The blue immobilizer light doesn't flash or turn on. Tried the valet key as well. The red light still blinks on the controller but thats all.
I read in the manual that if the key isn't opened all the way it can trigger the immobilizer to shut the car off but i dont know if thats the case.I was in a rush and i may have accidentally pushed the button that pops the key out and it bent a little while i was turning the ignition on. This car is brand new (got it end of July) and no mods have been done nor have I added anything to cause it to drain the battery or blow a fuse. Any ideas? Bad battery?
btw this is the second time its happened in that last 3 days. The first time I thought it was a dead battery but I realized I unlocked my door with the alarm pad and it worked. After closing my door and alarming it, I tried to start it and it started but it re-set my navi system. Never had this problem before.It's so weird
I'm getting it towed to the Acura dealership today
Old Aug 25, 2012 | 12:40 PM
still waiting to get it towed....
no one has any ideas as to why this happened???
Old Aug 25, 2012 | 01:46 PM
khoacu2's Avatar
i think something is worng with yours keys they can reset the system at acura for you
Old Aug 25, 2012 | 01:47 PM
khoacu2's Avatar
have you use yr blue tooth sometime when you dont turn off the blue tooth it will drain all yr power seen that most of the time
Old Aug 25, 2012 | 01:51 PM
I know you said it might not be the battery, but please check it!!
check the battery cables.
Make sure they are not loose and or corroded.
Since,Acura is coming to pick it up...it could very well be the battery.
hope you get it back better than ever!!
Old Aug 25, 2012 | 06:24 PM
Thank you for the response
The tow truck guy came and checked out my car and found the problem...the cable to my battery was waaay loose and it wasn't tightened all the way so that's what caused my car to pretty much be dead. I did check my battery earlier but didn't wiggle the cable...kinda just looked at it haha!Don't know how it got loose. Anyways saved myself a trip to the dealership and all is well!
Old Aug 25, 2012 | 06:28 PM
and we have a winner!
did you have any work done on the car, recently?
sometimes, I forget to tighten everything up when putting her back together.
Glad you solved the problem!!
Old Aug 25, 2012 | 06:39 PM
Nope. No work done at all as of yet. Just got it end of July. I didn't have any problems with it til the past few days. I'm glad it was a minor fix and nothing major. I always thought the dealership does a final check of everything to make sure it's good to go before they transfer it to the new owner :/. Oh well,just glad my car is up and running again
Old Aug 25, 2012 | 07:23 PM
Enjoy your pretty new car!!
Old Aug 25, 2012 | 07:25 PM
PyroDave's Avatar
they say they do, they really dont lol. i once got my car back from the dealer with low coolant. well below min, i was afraid it was gonna overheat and fuck up
Old Aug 26, 2012 | 09:56 PM
A bunch of shenanigans is what it is!! lol
Old Aug 27, 2012 | 08:54 AM
mrstak's Avatar
7# werC 2uoYeeS
i have never heard of this happening. i call bs
Old Aug 27, 2012 | 09:31 AM
Maybe not in the newer TSX's
but, on the 3rd gen TL, the Hands Free Link does go bad and causes a parasitic draw on the battery.
Old Aug 27, 2012 | 11:19 AM
mrstak's Avatar
7# werC 2uoYeeS
oh my mistake then. just find it weird...i would think the bluetooth is connected to the car, so if the car is on, then the bluetooth is on...if its off, then BT is off...but i guess not?
ssjkev16
Dec 22, 2024 02:51 AM
cycdaniel
Dec 17, 2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
