2011 tsx with A14 code
Old Mar 13, 2018 | 12:10 PM
adk's Avatar
adk
I have a 2011
Acura"><span style=Acura" /> Acura">Acura
TSX with 102k miles. I got code A14. I’m familiar with the A1
service"><span style=service" /> service">service
. However, I’m wondering about the “4”. The dealer tried to tell me that this is a timing belt change and the cost will be $2200. I know this car doesn’t have a
timing belt"><span style=timing belt" /> timing belt">timing belt
. My question is does the “4” indicate that the timing change or supporting components (sorry, I’m not very technical here) need to be replaced? Or do they just need to be inspected? Or is this an indicator about spark plugs and not my timing chain at all?
Thanks for looking.
Old Mar 13, 2018 | 12:14 PM
do you have the four cylinder or the six?
Old Mar 13, 2018 | 12:20 PM
adk's Avatar
adk
four cylinder. sorry, I should have mentioned that.
Old Mar 13, 2018 | 01:47 PM
jzhu625's Avatar
Maintenance Minder A
5 SPEED AUTOMATIC WITH TECHNOLOGY PACKAGE - Recommended service:
  • Replace engine oil*1
  • *1: If message, SERVICE DUE NOW does not appear more than 12 months after the display is reset, change the engine oil every year.
  • Independent of the Maintenance Minder information, replace the brake fluid every 3 years.
  • Inspect idle speed every 160,000 miles (256,000 km).
  • Adjust the valves during services A, B, 1, 2, or 3 only if they are noisy.
Maintenance Minder 1
  • Rotate tires
Maintenance Minder 4
  • Replace spark plugs
  • Replace timing belt and inspect water pump*5
  • Inspect valve clearance
  • *5: If you drive regularly in very high temperatures (over 110°F, 43°C), in very low temperatures (under -20°F, -29°C), or tow a trailer, replace every 60,000 miles(U.S.)/100,000 km(Canada). (6-cylinder models only).
lazytik
Jul 18, 2019 01:50 PM
rpetrover
Jul 13, 2012 06:16 AM
moreace
Jan 2, 2012 09:59 PM
moreace
Feb 2, 2011 08:56 PM
w1n78
Sep 30, 2008 02:30 PM
