Passenger Window Switch - Replacement Help
Old Jul 30, 2016 | 08:09 PM
A4orce84's Avatar
Hey Guys,
My wife's Acura TSX passenger side window switch does not seem to be working. We can only open/close the switch from the 'master' window switch located on the driver's side. I took it to the stealer-ship, and they said the following part needs to be replaced: 35760-TL2-A02
I've got a few questions now that I've set the stage:
1. Is this the correct Part Number for the driver's side switch? Google is not really showing me many images of the actual part, just diagrams of where it lives.
2. Is there a DIY or youtube video on how to replace this switch that anyone is aware of?
Thanks in advance!
--Asif
Old Jul 30, 2016 | 08:13 PM
ceb's Avatar
ceb
Originally Posted by A4orce84
Hey Guys,
My wife's Acura TSX passenger side window switch does not seem to be working. We can only open/close the switch from the 'master' window switch on the driver's side. I took it to the stealer-ship, and they said the following part needs to be replaced: 35760-TL2-A02
Thanks in advance!
--Asif
You mean passenger side, right?
Old Jul 30, 2016 | 08:16 PM
A4orce84's Avatar
Correct, passenger side window switch!
Old Jul 31, 2016 | 08:23 AM
cu2wagon's Avatar
What year?
That PN looks correct for the 2011+, for '09-'10, it looks like it was a -A01 revision.
To replace it, you just pop out the plastic switch panel from the door card, unplug the wiring harness, and remove a couple screws to free the switch assembly.
Look at the switch panel from the rear of the door, down at eye level with the switch panel/arm rest. You should see a little detent at the back of the panel. That is where you'd stick a little screwdriver or pry tool to pop the panel out. From there it's pretty intuitive to get the actual switches out.
It's really very simple.
Good luck!
PS. You can try eBay for the parts. There are usually switches floating around there for sub-$50.
Old Jul 31, 2016 | 08:40 AM
cu2wagon's Avatar
Also, you can get familiar with the Acura parts diagrams on any number of dealer websites. Such as this one:
FRONT DOOR LINING for 2011 Acura TSX SEDAN
Which will show you the part and give you the PN and approximate cost.
Old Aug 1, 2016 | 05:16 PM
A4orce84's Avatar
Thanks guys! Her car is a 2011 TSX.
Old Aug 1, 2016 | 08:17 PM
cu2wagon's Avatar
Then that is, in fact, the correct part number.
And here, just for you, is a video of how to pop the switch plate out. After that, it's intuitive to replace the switches themselves:
Old Aug 3, 2016 | 12:45 PM
A4orce84's Avatar
Thanks cu2wagon!
dubz ASPEC
Jun 3, 2025 08:48 PM
yakapo
2G TSX Problems & Fixes
Jul 26, 2016 09:26 PM
vito_ip14
Jun 13, 2016 04:29 PM
blackacuratl
May 1, 2016 01:47 PM
yousailor2
Mar 23, 2016 02:03 PM
