Double Din Unit on 2011 TSX W/Tech
Old Jul 2, 2018 | 05:18 PM
jprindle's Avatar
I want to install a double din head unit in my tech packaged TSX. I know I will lose the display for the temperature (I will take care of that later). Will the non-tech double din install kit work, or will I have to make something? I can change the original screen with something that will work with the new head unit, so I am not worried about that. Thanks!
Old Jul 3, 2018 | 12:56 PM
dhuynh's Avatar
Consensus says it's not possible. It's a lot of work. I'm sure if you can trace everything you need and have it work someway then go for it, as i would love to see this happen. But many have said they would but nothing as far as i know of has been done successfully. ELS has us in lockdown.
Great post on ELS bypassing and other words that I don't understand https://acurazine.com/forums/2g-tsx-...preamp-819501/
Are you going for better SQ or just want the modern toys? Phantom Audio can redo your stock amp to make it sound better so it still retains stock functionality. I haven't heard it personally but have spoken with him and he knows his shit.
I planned on molding a cradle into cavity where my stock screen is and magnetically attach for easy removal. and sticking an android tablet or ipad in there. but it's hot af and im lazy.
Good luck!
Old Aug 5, 2018 | 08:58 PM
jprindle's Avatar
Today I finished installing a Kenwood head unit. It was more work that I planned on, but everything works. The stock GPS antenna plugs in to the head unit, that was the only part that was easy! I have my temperature display in the glove box now. I still need to make that look good, but I am very happy with the way the system sounds now. I am finally happy with the car
Old Sep 16, 2018 | 01:38 AM
Jrvtecaccord's Avatar
Have a few questions as I also wanted to attempt to add an aftermarket HU to the Tech package.
Does the factory rear view camera still work on the OEM screen?
Did you remove the DVD player and replace it with the non-tech pocket?
Any other concerns?
Old Sep 18, 2018 | 12:38 PM
jprindle's Avatar
Any other concerns?
To have the temperature display, you need to have the OEM radio hooked up, because the display runs through the radio. So I wound up buying a radio display from ebay, and cutting the vent ports off so it would fit in the glove box. I had to drill a hole in the left side of the glovebox to get the radio wires ran, but I sized the hole to a plug that I have, so it will look stock when I am done and switch back to the factory setup. Because of this, I left the dvd player and radio in the bottom of the dash. I also left the OEM screen in place because my Kenwood unit could not utilize a second screen for anything except video playback. So I have the OEM camera and display working as normal.
I did take the GPS antenna connection out from the factory radio to use on my Kenwood, and plugged in an aftermarket GPS antenna into my factory radio. That way I have great GPS signal. I used an aftermarket antenna on the factory radio because when you disconnect the radio it will display the lost GPS signal screen until it can find itself again. So I can pull out the antenna that is tucked in behind the radio, get a signal, then tuck it back and out of sight.
You will need an antenna adapter that isn't very common. I will try to find what it looks like. It is not the typical Honda style. I didn't have it, so I soldered an adapter in place. I was too far into the project to wait for one to arrive.
I used a Maestro adapter for the steering wheel controls, it works perfectly.
If you have any questions, feel free to ask! I was really thinking of getting rid of the car because the factory radio was so bad, but now I am very happy. I have good sound
Old Sep 19, 2018 | 09:19 AM
dhuynh's Avatar
Any photos? I'm curious
Old Sep 19, 2018 | 09:24 AM
jprindle's Avatar
I haven't take any. What would you like a photo of?
Old Sep 19, 2018 | 12:40 PM
dhuynh's Avatar
Dash and hvac set up would be nice
Old Sep 20, 2018 | 09:55 AM
jprindle's Avatar
I am headed on vacation now, I will take some pictures when I get back.
Old Mar 5, 2020 | 03:08 AM
aczace87's Avatar
you back from vacation yet? I need to do mine! I’m so tired of this old headunit. Please explain in detail which headunit, harness and what frame for the headunit you used as the ones online say they aren’t compatiable with navigation.
Old Mar 5, 2020 | 10:10 AM
RTM's Avatar
RTM
That was his last post here. Maybe send him a PM, that may stir him up with an email.
Old Apr 29, 2020 | 07:33 PM
NYC TSX WAGON's Avatar
6th Gear
Looking to do this swap to my Wagon
Evening fellas. Anyone else do this? I'm looking for all and any directions that I can get.
1. Radio harness(s)
2. Antenna plugs / adapters
3. Anything else I might need.
Old Apr 30, 2020 | 04:29 AM
thefrenchdexter's Avatar
1. Radio harness(s)
What i've done :
I have a European Honda Accord (the same as TSX 2nd gen normally)
I have found this in Aliexpress it was delivered with all the necessary (harness, ...)
Old Apr 30, 2020 | 11:15 AM
6th Gear
Looks damn good
Looks greats. Does your climate control show on the screen?
Old May 1, 2020 | 05:59 AM
Yes of course (see it at 0"37), if not i send it back to the seller !
Old May 12, 2020 | 01:47 PM
6th Gear
Do you have part numbers or any type of info that I can research the interface on. If so can you post it. I'm looking to up grade my stereo and
I'm exploring all my options. So fare this looks to be the nicest.
Old May 12, 2020 | 01:52 PM
6th Gear
What i've done : https://www.youtube.com/watch?v=OupxW4meruo
Please post a few pictures. Side view and top view also.Thanks it looks awesome
Old May 13, 2020 | 02:14 AM
I have order a new one.
So il will post pictures when I will install it
Old May 13, 2020 | 12:11 PM
6th Gear
Thanks. Could you post info to order a set up. Im very interested in seeing if this will work for my 2012 Tsx wagon with Technology Package.
Old May 13, 2020 | 01:02 PM
6th Gear
Is this the radio setup
https://m.tr.aliexpress.com/item/400...7%237562%23475
Old May 16, 2020 | 07:33 AM
This one i the new one i've ordered.
My actually one is : https://tr.aliexpress.com/item/32919...archweb201603_
Old Jun 12, 2020 | 12:27 PM
T'eyes CC2 is arrived.
If i have some chance, i will mount it in my car this WE
Old Nov 4, 2020 | 03:51 PM
drejc112's Avatar
4th Gear
hello, do you know if all 10 speakers will work with this unit? I have a non navigation sistem with 10 OEM speakers , car accord europe version, 2012 facelift, wagon.
Old Nov 6, 2020 | 05:18 PM
drejc112's Avatar
4th Gear
€ 130,80 51% Off | Android Car DVD For Honda Spirior / Accord ( 2009-2013) Car Radio Multimedia Video Player Navigation GPS Android 10.0 Double DIn
https://a.aliexpress.com/_mqPbwVF
How would thus work? Anyone tryed ?
its interesting that it has sone kind of support for center speaker that i have in dash, doesnt say anything about subwoofer , if this supports all of oem speakers tgan i think is a good buy ?
Old Nov 9, 2020 | 11:23 AM
I have mount this one, i can't answer
Old Sep 11, 2021 | 03:24 AM
Acuratsx22's Avatar
Radio upgrade
Hi want to up grade radio in my tech model what wiring plugs do I need
Old Jun 22, 2022 | 02:28 PM
RaptorTL's Avatar
TSX Wagon w/ Tech
any update on this?
noraz123
May 15, 2020 01:29 PM
Jeremiah Blair
Dec 25, 2012 06:34 PM
jpadilla
Feb 28, 2006 02:29 PM
Blazn5
Jul 26, 2005 03:39 PM
