Blown speaker?
Old Jan 10, 2015 | 04:39 PM
ozymandias's Avatar
Blown speaker?
I have the tech package. The front right door speaker is buzzing, is it blown? What is the most cost effective replacement option while maintaining the stock level of performance?
Old Jan 10, 2015 | 05:49 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
When does it buzz? higher volumes with a lot of bass? lower volumes with a lot of bass?
Why not upgrade a little?
I just replaced all the door speakers in my MDX. My front door speaker was blown hence minor upgrade. It actually sounds A LOT better now with the new speakers (polk audios). Everything else is stock.
Old Jan 12, 2015 | 08:10 AM
soupi's Avatar
Im thinking about replacing all four of my door speakers, but not sure which speakers to go for at the moment. =/
Old Jan 16, 2015 | 08:32 PM
ozymandias's Avatar
It buzzes mid / low...especially with male voices. It's getting worse and worse by the day, and I think maybe the driver's side is starting now too but with female voices. WTF? I don't even listen to it very loud.
I don't want to upgrade all 10 speakers and I don't want to mess with the balance, so I am just looking for a good replacement which won't mess with the overall audio balance. If I can get something a little better while doing so and not breaking the bank, that's fine. I just have no idea how to do that. For example I don't know what resistance levels the stock speakers have. I imagine the door speakers don't have tweeters built in so I guess I should buy speakers without tweeters? Do I need a crossover?
Old Jan 17, 2015 | 10:03 AM
ulrblitzer's Avatar
Mine were sound the same (09 with tech), getting buzz and static when listening to talk radio and even radio commercials. I ordered these from Crutchfield Pioneer TS-G1644R 6-1/2" 2-way car speakers — for 6-1/2" and 6-3/4" openings at Crutchfield.com but technically speaking, you only need 1 way speakers since we have separate tweeters.
A bit pricier on Crutchfield, but you get the wire harness and mounting spacers included at their price, so it's worth the piece of mind.
Old Jan 17, 2015 | 10:07 AM
ulrblitzer's Avatar
See post #35 in my build
https://acurazine.com/forums/second-...g2-cu2-918883/
Old Feb 10, 2015 | 12:38 PM
soupi's Avatar
how'd these end up sounding?
Old Feb 10, 2015 | 08:34 PM
ulrblitzer's Avatar
It's a bit more treble since I'm running the one off the new speaker and off the OEM ELS system, but my ears adjusted. Can't tell the difference now. Just happy to not hear static and cracking.
Old Feb 11, 2015 | 08:27 AM
2snail's Avatar
I had the same exact issue
If it's the tech package the els will make non stock speakers sound off. Not wanting to have to redo everything I just bought a replacement from oemacuraparts.com it was 46$ for a replacement and sounds great. Whoever owned the car before me prolly did some damage. Anyways it's not hard to remove the door trim to get the speaker out. there's a YouTube video I found that has a step by step.
Old Mar 13, 2015 | 09:07 AM
harleeydc's Avatar
Hey ulrblitzer and 2snail I messaged you both but I'm still on probation as I can only have 1 message in my inbox for another 8 days as I just joined anyways how are the speakers holding up have the same issue as many others have with the speakers and want to replace with aftermarket ones just don't know if theyll blow as the stock speakers keep blowing thanks
Old Mar 13, 2015 | 02:45 PM
ulrblitzer's Avatar
The ELS sound tuning isn't all that great. Yeah, adding in different speakers made it sound a bit "rich" (running oem tweeter and built in pioneer tweeter) but your ears adjust after a few drives. They sound fine.
Old Mar 15, 2015 | 10:31 PM
2snail's Avatar
so far my oem replacement is holding up fine. I did notice now that my right rear door speaker is going out. ill probably order a replacement oem one once i get fed up with the noise. right now its not really noticeable yet.
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
polish_pat
Sep 25, 2015 12:24 PM
