Gas door help
Gas door help
Somehow after 7 years, my gas door separated from the black plastic.
black plastic also isnt secured to car
1) anyone know how door secures to plastic swing out?
2) do I need to purchase the swing out? Is there a part number for it? My door is fine.
can what I have be repaired? Or needs replaced?
thanks
pics attached. Appreciate any help.
thanks
The metal lid slides onto the plastic locking hinge assemble. Your pix shows a broken bit on the plastic hinge, that maybe the reason for separation. You will need to order part # 74480-TL4-G10 that is the inner plastic hinge assemble. Your metal lid is reused.
No sir. Was getting gas, finished, and went to pay inside. Older (homeless maybe), gentleman in a walker, walked into the car, and the body color door fell into the floor, and this piece came off.
Are you saying to order the new part (thank you for the number), due to the clip that holds THAT plastic part to the body colored door? Possibility I can super glue it?
I have no problem ordering the black plastic piece, if that main piece is broken somehow, but it seems to function and lock in place.
Hope I am wording it correctly.
I guess what I am saying is, looking at the plastic black piece, I put it back in the car, and it seems to function ok. If it functions ok, should I let it be, and not order another one? Appreciate it
Just to point out, the "black metal piece" that is the hinge... it just seems to "slot in" and not VERY well secured?
Enough reason to replace the hinge assemble, it should be secure! If you loose the lid, it's additional cost along with painting.
drove about a 100 miles with the hinge back in place, all is ok and secure.
will attempt to put the gas door on hinge and see if it takes- otherwwise will order the hinge in the morning
thank you
128 freeway miles later
glue is sticking
glue is sticking
I hadn't realized that you stole my car. I had to go out to the garage to make sure it was still there.
teng
3G TL Photograph Gallery
08-09-2007 07:09 PM
