Drop by Tein S-Tech
Old Apr 6, 2011 | 07:36 PM
UNEVAKNO's Avatar
Drop by Tein S-Tech
I waited until the winter and the possibility of snow was finished to lower the car. So far I am very satisfied with the handling and ride quality after the upgrade. Check out my car on the link and give me your feedback.
http://www.cardomain.com/ride/3839461/2010-acura-tsx
Old Apr 6, 2011 | 10:40 PM
sr20bet's Avatar
nice....i like the front color matched grille
Old Apr 6, 2011 | 10:43 PM
KillerG's Avatar
Op is too busy to care
because i love you, unevankaoao:
Old Apr 6, 2011 | 10:46 PM
09TSXTech's Avatar
Looks great with the drop.
Old Apr 6, 2011 | 11:39 PM
ed_423's Avatar
SeeYou2Crew #2
looks good
Old Apr 7, 2011 | 02:09 AM
ed_423's Avatar
SeeYou2Crew #2
hey man..after you settle...how high are you from the ground? and how many finger space u got? doenst look like there's much left
Old Apr 7, 2011 | 08:27 AM
Mr. NC's Avatar
You see me, I CU2
O thats sexy...I'll assume 1 or 2 fingergap?
Old Apr 7, 2011 | 06:19 PM
UNEVAKNO's Avatar
Thank you sir!
Old Apr 7, 2011 | 06:20 PM
UNEVAKNO's Avatar
You are the man! Hats off my friend.
Old Apr 7, 2011 | 06:24 PM
UNEVAKNO's Avatar
Its about 5-6 inches from the ground. I have to lift it to get my little hydraulic jack under it. Its barely a 1 finger gap in the rear and good luck in the front.
Old Apr 7, 2011 | 06:43 PM
KillerG's Avatar
get some wheel spacers, itll bring the wheels out a little more and make it look a bit more aggressive. something like 5 front 10 rear would be fine (most do 10/15)
Old Apr 7, 2011 | 10:01 PM
UNEVAKNO's Avatar
You read my mind exactly. Now when you say 5 and 10 is this the width or a part number?
Old Apr 7, 2011 | 10:03 PM
KillerG's Avatar
im referring to the width of the spacer, like how much they push it out (5mm / 10mm).
I have read on the forums that the way to go is 10mm front and 15mm rear (since the rears are slightly more tucked than the front) but i feel like 5mm front and 10mm rear would be enough in some cases. Take a look and see how close your rear wheels are to the inside of the fender and you'll get an idea of how deep you feel like going
Old Apr 7, 2011 | 10:08 PM
ed_423's Avatar
SeeYou2Crew #2
i've heard spacers are bad for the car?
Old Apr 7, 2011 | 10:14 PM
KillerG's Avatar
i dont know much about em but i havent read anything bad myself.
u remember which forum you came across it on or what problem it caused? we shall google
Old Apr 7, 2011 | 10:20 PM
Mr. NC's Avatar
You see me, I CU2
I believe the issue was that spacers apparently put undue stress on the bolts since the rims are farther out than they were originally designed
Old Apr 7, 2011 | 10:28 PM
KillerG's Avatar
Thanks NC, i used what you said to search it up and found this:
Wheel spacers are an evil thing but necessary on some applications to fit things. I don't follow what you mean about the stress that 10mm isn't enough? The less spacer the better with none being best. The more the greater the stress on bolts bearing and greater the deterioration in steering geometry, turning circle and a few other settings.
i know they are mainly done for style but in some applications are used for brake clearance with BBKs as well. I did also find posts advocating spacers, but lets just put this info out there
I do still think subtle spacers would totally help the look of the 18 stockies that unevakno has, and i also believe we have a few resident forum members running spacers too
Old Apr 7, 2011 | 10:31 PM
ed_423's Avatar
SeeYou2Crew #2
yeah i think spacers would make the OP's ride look GREAT! (already looks good as it is) but was just concern about the effects of spacers
Old Apr 7, 2011 | 10:33 PM
Mr. NC's Avatar
You see me, I CU2
Form > Function in this case, I've seen some aftermarket reinforced bolts that work in conjunction with the spacers as well.
Old Apr 7, 2011 | 10:35 PM
Mr. NC's Avatar
You see me, I CU2
ps. Your tails and headlights....Lamin-X? PLEASE tell me that the lightest tint cuz thats the look I want with my Grigio
Old Apr 7, 2011 | 10:43 PM
KillerG's Avatar
keep your tail-lights subtle nc!
http://5z8.info/facebook-hack_j2u1gc_russian-brides
Old Apr 7, 2011 | 10:45 PM
Mr. NC's Avatar
You see me, I CU2
It will look exactly like his Killer! I hate the blacked out look...nasty...just a light smoke, small details but good looking out!
Old Apr 7, 2011 | 10:53 PM
KillerG's Avatar
+2 on that bro, black out lights are gross!
if they look like OPs then awesome
Old Apr 7, 2011 | 11:53 PM
ed_423's Avatar
SeeYou2Crew #2
^ LOL
modesto!
emailnatec
29
Sep 28, 2018 04:27 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
4drviper
Sep 23, 2015 07:42 PM
