Drop by Tein S-Tech
Old 04-06-2011, 07:36 PM
UNEVAKNO's Avatar
Drop by Tein S-Tech
I waited until the winter and the possibility of snow was finished to lower the car. So far I am very satisfied with the handling and ride quality after the upgrade. Check out my car on the link and give me your feedback.
http://www.cardomain.com/ride/3839461/2010-acura-tsx
Old 04-06-2011, 10:40 PM
sr20bet's Avatar
nice....i like the front color matched grille
Old 04-06-2011, 10:43 PM
Op is too busy to care
KillerG's Avatar
because i love you, unevankaoao:
Old 04-06-2011, 10:46 PM
09TSXTech's Avatar
Looks great with the drop.
Old 04-06-2011, 11:39 PM
SeeYou2Crew #2
ed_423's Avatar
looks good
Old 04-07-2011, 02:09 AM
SeeYou2Crew #2
ed_423's Avatar
hey man..after you settle...how high are you from the ground? and how many finger space u got? doenst look like there's much left
Old 04-07-2011, 08:27 AM
You see me, I CU2
Mr. NC's Avatar
O thats sexy...I'll assume 1 or 2 fingergap?
Old 04-07-2011, 06:19 PM
UNEVAKNO's Avatar
Thank you sir!
Old 04-07-2011, 06:20 PM
UNEVAKNO's Avatar
You are the man! Hats off my friend.
Old 04-07-2011, 06:24 PM
UNEVAKNO's Avatar
Its about 5-6 inches from the ground. I have to lift it to get my little hydraulic jack under it. Its barely a 1 finger gap in the rear and good luck in the front.
Old 04-07-2011, 06:43 PM
KillerG's Avatar
get some wheel spacers, itll bring the wheels out a little more and make it look a bit more aggressive. something like 5 front 10 rear would be fine (most do 10/15)
Old 04-07-2011, 10:01 PM
UNEVAKNO's Avatar
You read my mind exactly. Now when you say 5 and 10 is this the width or a part number?
Old 04-07-2011, 10:03 PM
KillerG's Avatar
im referring to the width of the spacer, like how much they push it out (5mm / 10mm).
I have read on the forums that the way to go is 10mm front and 15mm rear (since the rears are slightly more tucked than the front) but i feel like 5mm front and 10mm rear would be enough in some cases. Take a look and see how close your rear wheels are to the inside of the fender and you'll get an idea of how deep you feel like going
Old 04-07-2011, 10:08 PM
SeeYou2Crew #2
ed_423's Avatar
i've heard spacers are bad for the car?
Old 04-07-2011, 10:14 PM
KillerG's Avatar
i dont know much about em but i havent read anything bad myself.
u remember which forum you came across it on or what problem it caused? we shall google
Old 04-07-2011, 10:20 PM
You see me, I CU2
Mr. NC's Avatar
I believe the issue was that spacers apparently put undue stress on the bolts since the rims are farther out than they were originally designed
Old 04-07-2011, 10:28 PM
KillerG's Avatar
Thanks NC, i used what you said to search it up and found this:
Wheel spacers are an evil thing but necessary on some applications to fit things. I don't follow what you mean about the stress that 10mm isn't enough? The less spacer the better with none being best. The more the greater the stress on bolts bearing and greater the deterioration in steering geometry, turning circle and a few other settings.
i know they are mainly done for style but in some applications are used for brake clearance with BBKs as well. I did also find posts advocating spacers, but lets just put this info out there
I do still think subtle spacers would totally help the look of the 18 stockies that unevakno has, and i also believe we have a few resident forum members running spacers too
Old 04-07-2011, 10:31 PM
SeeYou2Crew #2
ed_423's Avatar
yeah i think spacers would make the OP's ride look GREAT! (already looks good as it is) but was just concern about the effects of spacers
Old 04-07-2011, 10:33 PM
You see me, I CU2
Mr. NC's Avatar
Form > Function in this case, I've seen some aftermarket reinforced bolts that work in conjunction with the spacers as well.
Old 04-07-2011, 10:35 PM
You see me, I CU2
Mr. NC's Avatar
ps. Your tails and headlights....Lamin-X? PLEASE tell me that the lightest tint cuz thats the look I want with my Grigio
Old 04-07-2011, 10:43 PM
KillerG's Avatar
keep your tail-lights subtle nc!
http://5z8.info/facebook-hack_j2u1gc_russian-brides
Old 04-07-2011, 10:45 PM
You see me, I CU2
Mr. NC's Avatar
It will look exactly like his Killer! I hate the blacked out look...nasty...just a light smoke, small details but good looking out!
Old 04-07-2011, 10:53 PM
KillerG's Avatar
+2 on that bro, black out lights are gross!
if they look like OPs then awesome
Old 04-07-2011, 11:53 PM
SeeYou2Crew #2
ed_423's Avatar
^ LOL
modesto!
emailnatec
29
09-28-2018 04:27 PM
lanechanger
10-13-2015 10:56 AM
us285126
10-02-2015 02:03 PM
jmaxima03
09-27-2015 10:22 AM
4drviper
09-23-2015 07:42 PM
Quick Reply: Drop by Tein S-Tech
