Check emissions, check engine, check VSA help!
Old Oct 22, 2019 | 09:46 AM
Danosaurus's Avatar
My 2009 TSX has been consuming oil the last year or so, but my mechanic said that the rate of consumption is within specs according to Acura. It has around 130k miles on it. Yesterday the oil level light flickered and I realized I had forgotten to check it, sure enough it was low. So, this morning I put a quart in before leaving for work but as I started to back out of the driveway the motor suddenly began to shake/misfire, the check VSA warning came on followed by the check engine light and check emissions warning.
I double checked the dipstick, oil filler cap and fuel cap to make sure everything was tight. Scanned for codes and got P0304 Cylinder 4 Misfire Detected. Turned off and restarted a couple times but did not help.
I assume this is limp mode? Any ideas where to start troubleshooting? Is it related to engine oil or is that just a coincidence?
Sadly I live in a small town with one mechanic who is always booked and the nearest Acura dealership is well over an hour away.
Old Oct 22, 2019 | 09:47 AM
you have a misfire in Cylinder 4, Check the coil pack and spark plug. Potentially oil has fouled up the spark plug
Old Oct 22, 2019 | 10:21 AM
Danosaurus's Avatar
Thanks, sounds like a good place to start.
Old Oct 22, 2019 | 11:09 AM
fbt's Avatar
fbt
After you check the plug, might as well do a compression test. It will tell you why you are burning oil.
Old Oct 23, 2019 | 11:07 AM
Danosaurus's Avatar
So I replaced the plugs, which were due anyway, and the misfiring continued. Swapped cylinder 4 ignition coil around and the misfired followed, so it appears to be a bad coil.
Question...do all four need to be changed at the same time, or just the bad one? Any opinions on OEM vs aftermarket coils?
Old Oct 23, 2019 | 11:25 AM
bad one only. www.rockauto.com get an OE equivalent (NGK) https://www.rockauto.com/en/moreinfo...442648&jsn=852
vs. OEM: https://www.oemacuraparts.com/v-2009...hole-coil-plug at 117
Old Oct 23, 2019 | 01:04 PM
Danosaurus's Avatar
Thanks very much for the help, ordered from Rock Auto!
Old Oct 25, 2019 | 08:28 AM
Danosaurus's Avatar
Received the coil yesterday from Rock Auto, installed last night and my TSX is back up and running great! Thanks again for the help guys!
Old Jan 8, 2020 | 05:14 AM
ImBroke's Avatar
I just replaced all 4 coils on mine. Too many experiences with VW coils, when one fails the other three are not far behind.
Old Feb 14, 2020 | 10:49 AM
aabh16's Avatar
Hello, the Acura dealership diagnosed P0304 Cylinder#4 Misfire on my 2010 TSX. I am planning to change the spark plugs and coil this weekend.
Can you please tell me the numbering of the cylinders when I am looking into the hood from the front of the car?
Is it:
Cabin
1 2 3 4
Front Bumper
sr20bet
May 8, 2013 06:07 PM
panzer948
Nov 27, 2012 07:01 PM
acuratsx228
1G TSX Problems & Fixes
27
Sep 12, 2012 06:14 PM
djeuro
2G CL Problems & Fixes
Dec 13, 2010 12:52 PM
speedemon90
Apr 25, 2010 05:47 AM
