aft fluids
Old Jan 7, 2014 | 02:06 AM
boki_cu2's Avatar
aft fluids
hi guys
just want to see what is everyone using, i been thinking of changing my dw1 to castrol fluid http://productsforyou.castrol.com.au...ultivehicle/35
or
http://www.valvoline.com.au/explore-...-synthetic-atf
after doing few changed with dw1 it just doesn't seem that great , i changed from z1 fluid originally.
Old Jan 7, 2014 | 06:37 AM
Simba91102's Avatar
Old Guy
Originally Posted by boki_cu2
hi guys
or
The general consensus (here anyway) seems to be that the Honda ATF is the way to go. I'd be curious what you mean by "just doesn't seem that great". How do you define that, and/or compared to what? It's specifically designed for Honda transmissions, and though as a rule I'm generally skeptical of the need to use in-house branded fluids, the ATF does seem to work best in performance and protection.
Old Jan 7, 2014 | 08:01 AM
bagwell's Avatar
2010 TSX
+1, I'd definitely stick with the OEM stuff here (DW-1) - Honda trannys CAN BE very finicky.
Old Jan 7, 2014 | 08:23 AM
BattleofXs's Avatar
Stick with OEM and throw a quart of GM Syncromesh with friction modifier in.
Old Jan 9, 2014 | 04:37 PM
cris_crozz's Avatar
i don't know about the TSX's automatic transmission but on my 5speed manual EK hatch S40 transmission i did switch to castrol fluid. And never had a problem.
Old Jan 10, 2014 | 03:53 AM
boki_cu2's Avatar
i did email castrol in regards of their fluid still waiting on response
Old Jan 10, 2014 | 05:37 AM
ceb's Avatar
ceb
I'm confused.
Since it is absolutely impossible for the consumer to tell the difference between fluids (except when you use an improper viscosity), I'm unsure why anyone would want to experiment with unproven fluids.
Old Jan 10, 2014 | 05:46 AM
TSXV6Guy's Avatar
Honda automatics are special beasts and the fluid composition is critical for their reliable operation. I would only recommend OEM fluid.
Old Jan 10, 2014 | 04:14 PM
cris_crozz's Avatar
Originally Posted by ceb
I'm confused.
It's not an experiment. My dad worked as Honda Tech and Service advisor at a Honda dealer in Manila back in the days and he said they even use the same oils they put in the motor, in the transmission. But that was for manual transmission. And that was way back when EK Civics were the current models.
Old Jan 13, 2014 | 02:49 PM
bagwell's Avatar
2010 TSX
link?
this is only for MT cars tho, right??? not automatics
Old Jan 13, 2014 | 07:11 PM
cris_crozz's Avatar
^ this for automatics.
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
