2G TSX Chat, Chit, and General Info Thread
I've heard of some space blanket type material that you could put up there that doesn't cause mold to grow.. but the ridge vent.. it is SUPPOSED to flow air by natural design. kinda like a grill intaking air from the bottom while the hot air rises out the top.But anyway something doesn't seem to be working, 147F.. those temps should be in like Texas or FL heat when outside temp is close to 100F.
Also... if I want a fan now I have to cut a hole in the side of the gable because I only have a ridge vent. Or just put a box fan in the middle of the attic facing up. But that sounds kinda stupid. sighhhhh
Maybe no cool air is being ingested via eaves or soffits so the air is just stagnant?
Are they clear?
ok.... so I have ridge ventilation as I have come to realize, and my amateur investigative skills point to ridge vented attics not needing attic fans (supposedly they are really good at venting hot air). I confirmed I do have continuous soffits around the entire outside of my house so there should be sufficient flow. I just got up there with a laser thermometer and today it was 84F and sunny.. I measured 147F under the roof. That seems waaaay high. I don't understand what's happening. I have about 10in R30 insulation running along the entire floor of the attic. It was measuring about 110F and the the gable was measuring around 135F. I have no trees or debris that could build up over the ridge vent, nor really anything that could block the soffits around the outside...
What gives??
What gives??
The 110° is measured off the upper surface of the insulation?
Could be that your ridge vents aren't sized big enough, but I am no expert there. Are they completely clear and open?
A gable vent is what I was suggesting a few posts back on this topic (from a different post you made)
Yeah, so I THOUGHT I had two gable vents.. one over my garage and one over the bedroom in the front of the house... but when I went into the attic the gable is completely boarded up. no vents. So those vent looking things on the front of the house are just for show?? idk.. seems weird. (Maybe they didn't cut the hole, and the builders were like.. fuck it, just put the vinyl venting on the outside and no one will know.)
Im gunna go up on my roof today and see if the ridge vent is clear.. maybe when it was installed on shot to the roof it got squeezed shut? Idk if Ill be able to tell if it's ok or not. Should I be able to feel airflow through the ridge vent?
For others that I asked.. Yeah the roof was 147, the trusses/side walls were 125-135ish... and directly on the insulation it was 110F.
Good luck with the ridge vents.
I'm a particularly big fan of the fake shutters. Especially when you can obviously see that if they were real, they'd be too small to cover the windows when closed.
It's like PepBoyz stick on vents for your car. (which is what it sounds like ssjoe has on his house)
Ultimate Ricer.
Ultimate Ricer.
I think it's that McMansion Hell website where they point out stupid shit like that. There are houses that have gables on the roof, but nothing behind them. They're like the equivalent of house roof warts.
I'm gonna put a TypeR emblem on my house now.
My AC problems have come to an end... Called AC guy out, and he took a look at the furnace and told me I wasn't getting nearly enough airflow (never knew, because it's been the same since I moved in). He looked at the control board and told me that when the unit was installed the settings were never adjusted for my specific house, meaning CFM was set to less than 500 as "out of the box settings". He changed the switches on the board to match my 2ton unit for max flow of 800CFM. Everything seemed great when we restarted the system, however the AC is on a time delay and the weirdest part was that it was flowing at a really high rate until the AC actually kicked on. then CFM dropped below 500 again (even though we made the necessary changes on the board). He couldn't diagnose why the flow rate was decreasing when AC was kicking on and told me my thermostat was bad, and when the signal was calling for cooling it wasn't sending the right command for fan speed. I said "thanks I'll look into it." I was super skeptical that my thermostat was "bad" seeing how this house was only built in 2009, and that the thermostat literally sits in a static position with nothing that could really cause the PCB to heat up, break solder, or have loose connections. Just didn't make sense that everything works EXCEPT the fan speed when AC turns on...... Read through the entire thermostat manual and came across "furnace setup" which indicated a few options for AC flow rate. COMFORT/EFFICIENCY/MAXIMUM. The default setting on the thermostat was set for COMFORT (which helps control humidity by flowing at a low rate)... I changed that to MAX and Im now flowing at 800 CFM and my house actually dropped to my set temperature in the middle of the day, which never happened before. It's finally fixed, I can't believe it.
It astounds me that the previous owners lived like this for 8 years...
Glad it's all fixed!!!
Got this guy local to me who's selling this kit. Although he's saying it'll fit 09-14, but everything I've seen online says 09-10. Are the differences really that major that it wouldn't fit? Also he doesn't want to go lower than $300 for the set, but since it only has a primer, it still needs paint. Any guesses about how much that would be for the 4 pieces?
https://www.amazon.com/2009-2010-Acu.../dp/B00I4ZNP6E
for the paint i would assume more than buying the rear and sides of a OEM site that comes pre painted. the front i'm not sure if it come painted or not when it is purchased.
I learned my lesson on the front lip made out of that stuff. Shipping wrecks any chance of it fitting flush, not to mention the material flexes so much it's hard to keep the paint on it. I'd say only for black cars where you may not need to paint it, it might be worth it...
