2G TSX Chat, Chit, and General Info Thread
VTEC just kicked in, yo!
What's this Work TPMS adapter that you speak of? Got a P/N? Didn't know the Work valve stems aren't a direct fit with the TSX TPMS.
Graphite Ghost
when I went to get my tires mounted onto the wheels, I forgot to hand them the blue work valve stems so I'm using some ugly ass OEM ones that came with a second hand set of TPMS.
http://www.workwheelsonline.com/tpms-l-shape-adapter-set.html
I bought them from works. It's a loop you mount the tpms into. Then it connected to the valve stem.my wheel has hole in center of rim so externally I have about a 3 inch stem to make sir easy.
TPMS L Shape Adapter Set (For 2 Piece Valvestems)
These came with my wheels, but I forgot to give them to the tire shop
http://www.workwheelsonline.com/work...stem97811.html
I want them on.. but I don't feel like paying another $80 to remount the tires just to get these stems on
Hi gaiz, I have no idea what the topic is about butt hi!
butt. Simon touched the butt
Iz these joints legit?
http://www.ebay.com/itm/121508719796?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Graphite Ghost
oh ic. This is a multipiece wheel thing. I guess I shouldn't run into any problems using the OEM TPMS with my less ballin 1pc XD9s
WORK Emotion XD9 / XT7 / XC8 / 11R Valve Stem (Blue)
Graphite Ghost
4 New Pacific TPM1A Tire Pressure Monitoring System TPMS Sensor Made in Japan | eBay
TSX AMG Type //M i-VVT
^Saw that a while back. That's pretty much me LOL
Graphite Ghost
oemacuraparts 26.83
find it cheaper maybe
Graphite Ghost
so you are going blue......and losing the tpms?
just put a blue cap on your tpms....isnt that a better solution
I thought about just putting the blue cap on... but I want the whole thing to be blue
Received 7,772 Likes
The following 2 users liked this post by cu2wagon:
MC MiYoung3269 (05-07-2015),
xtcnrice (05-07-2015)
Graphite Ghost
ok yeah im pretty sure thats not going to work WITH your tpms but in place of.....i could be mistaken but I dont think so for sure
Ordered 4 RDX TPMS brand new for $88. Thanks ROB
the stem thing is part of the TPMS as far as i know.
So all you can do is attach the blue cap.
Graphite Ghost
buy cheap ones and use a bit of something on the threads......otherwise the 2 diff metals with GALL together. then when you go to take the cap off.....the tpms threads crumble.
i use a touch of anti seize but you can use other stuff.
that why all new caps are plastic/
The following 2 users liked this post by robpp:
justnspace (05-07-2015),
This jobber attaches to the rim inside the tire with the short threaded portion sticking out to the outside world:
Assuming the stem is two pieces and has a mating thread, you should be able to screw the blue shaft portion onto the silver jobber from above:
And then, here is where it gets ghettoAF, screw the factory TPMS sensor through the metal eye of the jobber in step 1 such that the eyelet is acting as the "Sectional cutaway of wheel" in this image:
But I know nothing and that's just guessing and making stuff up.
oh, and don't park near a middle school because the blue caps will be gone and on someone's Huffy promptly.
Not that I know about that firsthand or anything.
Your guess makes a whole lot of sense. But it seems to be too much of a hassle to get going. Plus if I get the mounting hardware for Work, it'll cost $80!
yeah, i plan to change out my blue valve stem from my TE37s to TPMS valve stems.
i really like the look of the colored valve stems but having the car go crazy and yell at me every 5 secs is un-barable.
Ricers
Oh hey, you have cum ho tires
What about them?
Quick question, to replace the DRL with a different DRL bulb, it's just plug and play right? No need to remove the bumper or anything.
he asked the night that we were hanging out....matter of fact, i had gotten an email when we were talking...
i should have read it and asked you right then and there
True. Reach in through the hood.
cu2 wagon, what side of town are you on?
Yeah plug and play. And what crabman said. I wanna meat your wagon.
