2G TSX Chat, Chit, and General Info Thread
Omg that's fucking scary... I'm guessing at least one person died since the video started with a message that had "RIP" in it. Really sad.
edit (reposting):
edit (reposting):
Originally Posted by xtcnrice
Guys running Progress RSB. Did you grease the bushings (I will be doing this)? Any issues with noise/clunking?
One died four injured. They also were standing where they weren't allowed to stand.
on the rsb: mine dosen't make any noise but I was pretty liberal with the grease. I was sure to put a lot... because on my dad's car the noises it made were freaking horrible until we re-greased it for a 2nd time. Didn't want to do that with mine.
Yeah the stupid allen key shit broke. It's a stupid design. I amazon prime'd it so i had no car for only a day.
I replaced it with the Moogs one which you can use two wrenches on instead of a wrench + allen key. maybe you just want to have peace of mind and order 2 of them. It's only like $20.
then attempt. mine came right off.
also, yu shud have 2 sets of bushings. i bought the greasable ones extra.
use them. otherwise if you need grease you have to remove the bushing.
and use special POLY grease. its almost clear and real sticky.
. Parts in Canada are like doubled the cost... plus with the exchange rate, probably gonna end up being like $50 lol
spray the allen area with your rust buster for a bit.
Prothane 191750 - Super Grease 3 Pack. Prothane 19-1750-BL
My second one came right off, dunno why the first one was such a bitch. Anyways yea do what rob said, spray some rust off stuff or liquid wrench on first. If you break one you can always just Amazon it overnight
Should I apply antiseize when putting the bolts back in? Any bolts I should NOT be applying antiseize onto? Only thing I've heard not to apply it onto are wheel studs. Sorry for the ignorance.
Also, here is a video for those interested about water on collonite 845 to show it is in fact pretty waterproof.
https://www.youtube.com/watch?v=Jw2_...ature=youtu.be
Thanks Rob. I bought Prothane grease for poly bushings. Something like this:
Is anyone else's door sills really rusty? Since I had it out i decided to try and refinish it...
Sanded all the crap off with a 3m pad and sprayed a coat of high gloss clear. idk why Acura didn't coat it in the first place. all 4 of mine are super rusty
super shiny now, even though now its just temporary until the new ones come...
Just pulled the trigger.. Stage 1 exedy clutch and rsx type s flywheel is coming soon.. Hopefully installed by the beginning of next week along with my new CMC and modded CSC..
Question about all this RSB talk:
I understand the Progress bar needs the mounting holes in the chassis reamed open to fit the oversized bolts. Does anyone know definitively *why* the Progress bar needs the oversized bolts?
I suspect that it's because the larger bar will be stiffer and transfers more stress into the pivots so the larger bolts provides more margin to yield. I have some reservations about drilling out the mount and not being able to reverse the mod in the future and was wondering why they don't just go with higher strength fasteners. Unless the tapped threads are the weakest link and the bolt with backer plate is addressing it?
I suppose I could go calculate the old/new stress ratios and bolt strengths but I figured someone else might have already looked into it.
So yeah, anyone know for sure?
I feel like they were just playing it safe with the larger bolts and reinforcement plate. I was doing some googling before i got mine and there are tons of horror stories of people tearing off their rsb mounting points right off the frame.
I think it would be reversible but you just have to get some new bolts i guess.... rob did it. Rob what did you do about the larger hole?
It's interesting though, my friend just got the progress RSB for his RDX and i noticed it doesn't come with any bigger bolts or reinforcement, you just re use the current one. So i wonder why they decided that was adequate.
Yeah, I was thinking that going back to stock could be as simple as using a longer version of the stock bolt with a nut on the back side.
Maybe I'll look at the maths to figure out the pullout force for the stock tapped threads. Intuitively, I just don't see a radical advantage to the larger bolts since it's only a step or two larger, if I remember correctly.
Thanks for all of the comments/input on the RSB guys. I really appreciate it!
Now, I cheaped out and will be reusing the OEM endlinks. Do you guys suspect using the "stiffer" setting to be unsafe with the OEM endlinks?
I'm also lowered on TEIN Street Basis and will be installing a rear camber kit soon, if that matters at all. I doubt it but figured I'd list them anyway since they're all suspension related.
Oh and nice video OP. I love the Collinite stuff. Best part is, that bottle will probably last you a life time if you're using it correctly!
edit:
No plans on tracking the car, but I will be taking some turns harder than usual since I should be able to after upgrading the RSB.
edit:
edit:
edit:
And yea sliding the back out is fun... now that i figured out how to do it, I do it all the time lol.
Quit driving like a maniac.
the progress bar uses Energy suspension busings and bushing brackets.
they require the larger hole.
when i went back to stock I bought a new set of energy suspension bushings that fit the oem bar. a little black paint and all looks good and oem.
i also looked at just reusing the oem hardware and with some good washers I dont think you would have a problem. you dont enlarge the hole all that much.
you cant get a larger bolt because the oem has the nut welded on.
lets stop the BS. the Progress endlinks ARE A VAST IMPROVEMENT OVER STOCK.
i bought them and can tell you they are worth every penny.
anyone who has a comment that has NOT used them or tried them is full of shit/
Lol yeah I've been doing some reading. The endlinks are literally what connects the bar to your car. If the mounting plate/bracket isn't the first thing to break off the car, the endlinks are likely the next most vulnerable thing. However, I also read that this isn't a required item unless you AutoX/track the car, since DD usage should mean less hard turns in the same period of time.
However no one on this forum seems to track their CU2 (except maybe maiku at the time), and I feel there is a correlation with why no one has reported a busted end link due to the thicker RSB.
I'm gonna skip the Progress/Moog endlinks and only upgrade if mine decide to break on me. I will not be tracking this car so I don't think I'll see any issues down the road. Thanks everyone!
