Wiper control arm replacement
Old Jun 4, 2009 | 06:35 PM
xbldr's Avatar
Has anyone had this problem:
02 3.2 TL , wipers go too far to the left. They also don't stay in the ready position between wipes. It does it most of the time. Any one know about this problem? Thanks
Old Jun 4, 2009 | 08:04 PM
hANDYcaptd's Avatar
It's the Halladay season!
^ What do you mean they stay in ready position?
And going to far to the left....do you mean it hits the side of the windshield?
Old Jun 4, 2009 | 11:13 PM
smartypants's Avatar
xbldr :
Do a search ! This is written up several times and is also (I'm pretty sure) in the DIY section.
smartypants.
Old Jun 5, 2009 | 07:11 AM
juanclopez2786's Avatar
https://acurazine.com/forums/2g-tl-problems-fixes-117/windshield-wiper-stepping-motor-issue-706465/
Old Jun 16, 2009 | 11:51 PM
edinjersey's Avatar
If you're feeling lazy, just put in a 22" blade instead of the 24" blade. That way, it won't get caught on the side. Of course, you lose a little bit of a blade, put in a pinch it should work until you can get the problem fixed.
Old Jun 17, 2009 | 01:11 PM
SYLKIE's Avatar
Wye-Ey-Fore Sicks-Spd
I had this same problem (sort of). On the ends of the arm linking the wipers, there are small white plastic ball joint cups for the ball on each wiper arm. Sometimes they come off, or wear out. I bought a new OEM one for about $21 at the dealer. You hafta unclip the hydraulic hood arms and washer spray hoses, and then lift hood up to the windshield (be careful of winshield). Then remove the black plastic wiper motor/linkage covering that runs along the bottom of the windshield to get at the linkage arm. Unsnap and replace the arm.
csmeance
Jan 7, 2026 06:25 PM
marcelft
Jul 10, 2018 06:17 PM
Aging-Hacker
Oct 5, 2015 11:44 AM
gqdabien
Sep 8, 2015 11:41 PM
nuldabz
Sep 3, 2015 05:49 PM
