Wierd spark plug
Old Dec 30, 2010 | 12:53 PM
SLushhYYY's Avatar
Keep It Simple in
Wierd spark plug
How do i take it out? theres no bolt just a piece of rubber
Old Dec 30, 2010 | 01:00 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
thats alil strange... consult a shop manual or a mechanic... maybe the metal sleeve has to be removed to get to the plug....
Old Dec 30, 2010 | 01:14 PM
AMUA6's Avatar
ScoobyZINE
Looks like the piece of rubber out of a spark plug socket. See if you can fit another socket over it and push the rubber on down to the base of the plug.
Old Dec 30, 2010 | 01:48 PM
SLushhYYY's Avatar
Keep It Simple in
It's the rubber at the end of the coil I think...
Old Dec 30, 2010 | 01:58 PM
SLushhYYY's Avatar
Keep It Simple in
Ima moron... Problem fixed guys thanks lol
Old Dec 30, 2010 | 02:02 PM
DarkSithCL's Avatar
are they all like that or just this one?
Old Dec 30, 2010 | 02:03 PM
DarkSithCL's Avatar
...and the green velvet pony goes to the kid with the runny nose....
glad you fixed it.
Old Dec 30, 2010 | 02:13 PM
SLushhYYY's Avatar
Keep It Simple in
IT was just that one because I didn't remove the coil by detaching the wire, I just yanked it out and I guess the little bottom part got stuck on it while I was pulling...haha
So once I removed the coil properly,the rubber piece came off with the coil
Old Dec 30, 2010 | 03:23 PM
DarkSithCL's Avatar
Zing...
Old Dec 30, 2010 | 05:37 PM
01tl4tl's Avatar
these coils are like Grandmas fine china- treat like fragile glass!!
No YANKING them out
and set them on a towel when removed
Old Dec 30, 2010 | 05:46 PM
SLushhYYY's Avatar
Keep It Simple in
^^I did just that after i realized you could unplug them haha
any reason why my power steering is whining now after changing spark plugs?
Old Dec 30, 2010 | 09:32 PM
Karanx7's Avatar
Unregistered Member
Wow it seems like everyone's power steering is falling apart.
Old Dec 30, 2010 | 10:12 PM
totaledTL's Avatar
Not related.
Old Dec 30, 2010 | 10:30 PM
DaveS221's Avatar
No YANKING them out
oops
Old Dec 31, 2010 | 12:45 PM
01tl4tl's Avatar
p/s noise, flush the fluid twice from the entire system
ck ps belt condition and tension, its tensioner is manually adjusted- old school style
Old Jan 1, 2011 | 02:34 PM
fsttyms1's Avatar
Its not related. nor can it be.
Old Jan 3, 2011 | 04:27 PM
ThreePointTwoTeeEl's Avatar
3.2TL
So I got my idler pulley tensioner replaced because it had some slight ticking. Long story short, the PS pump, reservoir, belt and hoses had to all be disconnected and put back together to get to that idler tensioner. After that was done my PS pump stopped making noise.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
