2002 acura got a PFINH code
what FLUID exactly did you use for trans fluid??? honda atf?
how much -3 qts?
by what method was the fluid changed- drain and refill
this is important to the trans!! the wrong fluid will destroy these trans fast
did a shop do a machine powered trans flush and new spark plugs for you?
If so make sure it got the correct NGK Iridium (upgrade) or NGK Platinum (came with stock) spark plugs it requires
they are about 8-10 dollars each,,not 2 dollars each
quickie shops will throw some bosch or other non approved plug in--a few miles later they crap out and multi cyl misfire with poor running occurs
someone recently posted pics of bosch 4plugs after only 5000 miles in a TL- loaded and carbon coated--not good~
how much -3 qts?
or power flushed and filled it with dex3
or knocked a wire loose for a selenoid under the car
or one of them happened to fail at same time
there was a member with immediate no shift- stuck on the rack at trans shop, turned out to be a selenoid
iirc
if this old mind recalls
iirc
mada51589
Jan 9, 2025 04:40 PM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
