What to consider when or id changing your TL Factory Sterio
Old Apr 19, 2006 | 10:52 PM
AccTL1999's Avatar
Well i am new to this site. i woudl just liek some good help and advice, i am thinking of changing my 1999 Tl factory Sterio completely.
Can some one tell me what i should take into consideration when i an changing it.
Will my Alarm be able to work properly??
Will my anti theft system work properly??
Old Apr 20, 2006 | 01:20 AM
optomos's Avatar
I=X - optomos
You don't have to worry about your alarm. How far are you wanting to go on the stereo($$) and are you looking for sound quality or just something to go boom. Also will you be doing most of the work yourself, using an installer or a combination of both.
You can also check out the audio/video section for some ideas and inspiration.
Old Apr 21, 2006 | 10:21 AM
AccTL1999's Avatar
More questions
Well thank you, I was wondering if my anti theft would work properly.
I am really trying to install a computer in my car. The Factory stereo is kind of getting on my nerves even though the sound quality is good.
I know with some cars if you take the factory stereo out you need some kind of adapter so that the security system works
Old Apr 21, 2006 | 12:31 PM
fsttyms1's Avatar
nothing will be affected by removing the stereo
Old Apr 21, 2006 | 03:04 PM
chabooky's Avatar
--BASS FANATIC--
yeah nothing will be affected if you take a look around the site you can read up on some stuff other people have done. I work a car audio store so by all means ask away... yeah your factory keyless entry wont be affected. nothing will be. UNLESS you have the Bose system pretty sure you do. If you do switch it out you will need to intergrate your speakers in with the new radio. Ur sub wont work but yeah depends how far you wanna go in my signature u will see all the knicks and knacks i've done and i love my system to death
welcome to the site man!!!
Old Apr 21, 2006 | 03:16 PM
fsttyms1's Avatar
HuH??? They all have BLOZ and you dont have to integrate your speakers with the new radio. There are adapters that make it plug and play and will bypass the stock EQ. The only thing that wont work is the oem sub, which will require a little custom wiring if you want it to work
Old Apr 21, 2006 | 03:38 PM
optomos's Avatar
I=X - optomos
Streeteffectz has a DIY on it under the audio/video forum.
Old Apr 21, 2006 | 03:42 PM
fsttyms1's Avatar
Old Apr 21, 2006 | 03:46 PM
chabooky's Avatar
--BASS FANATIC--
Yeah well if he didn't have the adapter then he would have to do it the long way right?
Old Apr 21, 2006 | 07:24 PM
sbuswell's Avatar
I need 2 more gears
if you want to replace the stock HU do yourself a favor and replace everything, it will be worth it. the stock speakers are just a 6" paper cone full range speaker with no tweeters. they are kinds shitty and each has it's own seperate amp. If you want to do it the right way just take off the Blose shit out and put in some good equipment.
Old Apr 21, 2006 | 07:54 PM
optomos's Avatar
I=X - optomos
No adaptor. Just cut one end of a rca cable and two wires on the sub plug and connect them together.
BoricuaTL
Apr 8, 2016 01:08 PM
scionxb3003
Oct 2, 2015 05:50 PM
Aleax
Sep 11, 2015 11:31 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
