Way to turn A/C off permanently using Auto Climate
Old May 30, 2006 | 10:05 AM
rezn8's Avatar
Whenever I turn on the climate control it usually kicks in with the A/C for which I have to manually turn off the A/C using the A/C button.
Is there are way to run the climate control similar to other cars where you turn on the fan and if its too hot you just turn on the A/C?
Thanks for all the great info on this board.
Old May 30, 2006 | 10:08 AM
pmptx's Avatar
Honda+Blue=My garage
Simply press Full Auto then press A/C to turn compressor off, the thermostst will then control fan speed only.
Old May 30, 2006 | 10:50 AM
rezn8's Avatar
Yeah but I'm trying to find a way not have to turn off the A/C each time I turn on the climate control. I want to turn it off and make it stay off until I tell it otherwise.
Old May 30, 2006 | 11:10 AM
fsttyms1's Avatar
just dont use full auto. If its not on full auto the AC is on only when you turn it on. and you have full control of the fan speed.
Old May 30, 2006 | 01:26 PM
rezn8's Avatar
Is that right? I guess I'm a little too used to have a little green light come on whenever I turn on the AC.
Old May 30, 2006 | 10:59 PM
darshan_patel's Avatar
so the compressor remains all all the time if u have the climate control on FULL AUTO??
or it goes on/off.....i doubt that cuz the temp remains constant in the cabin! so its gotta be on the whole time!! man..a lotta gas i say?
Old May 31, 2006 | 06:29 AM
MikePA's Avatar
No, the AC compressor, or heat, come on when needed to maintain the temperature you set. That's the whole point of AUTO.
Old Jun 1, 2006 | 04:57 AM
chewi's Avatar
I've stopped using my A/C for almost a year now...
I just turn it off right away After i hit the auto button to save gas.
Old Jun 1, 2006 | 05:49 AM
MikePA's Avatar
and how much gas have you saved?
Old Jun 1, 2006 | 07:45 AM
chewi's Avatar
probably not much, but I live in canada so its not that hot in the summer.
Old Jun 1, 2006 | 08:19 AM
TL Maestro's Avatar
A/C compressors aren't using more than 5-7 HP anyway, so I wouldn't lose any sleep over whether you have it on or not. The benefit of a comfortable cockpit far outweighs the miniscule amount of power to be gained from having the compressor off.
If you were talking about a 125 HP 4-banger, it would be a different story...
Old Jun 1, 2006 | 11:31 AM
rezn8's Avatar
Hey Maestro,
Then maybe you can you can answer this for me...the reason I want to turn it off is because I feel that I lose some power in my 02 TL (100k) when I have the A/C running. When it's off it just seems to me that my car accelerates smoother and shifts more consistenly. This is really only noticable in stop and go city driving.
Does that sound normal for a 3.2 V6?
Old Jun 1, 2006 | 01:23 PM
antlive's Avatar
Cruiser
My AC has seemed to stop working all together. I get on air at any temp. I'll be checking the fuse to see if it's that. But what else could it be?
Old Jun 1, 2006 | 02:10 PM
TL Maestro's Avatar
Arrow
Originally Posted by rezn8
Hey Maestro,
No, that doesn't sound normal at all. I have an '02 as well, 120,000k and it still pulls like it did the first year I had it, and I'm running the A/C non-stop out here in sunny So Cal.
You might want to take it in and see if the A/C clutch is still working correctly and have them check all of your belts too.
Old Jun 1, 2006 | 03:08 PM
antlive's Avatar
Cruiser
Spoke to my mechanic and he said it sounds like the blower and sensor is shot...... hope it doesn't rain while I'm driving for a while........
Old Jun 1, 2006 | 03:56 PM
acurabum's Avatar
My TL-P 02 with 75k miles do the same thing . Compressor of the A/C turn on/off too frequently and this will affect my acceleration .
Old Jun 1, 2006 | 03:58 PM
rezn8's Avatar
Was hoping it wouldnt come to that. I'll drive it around a bit more to see how bad it really is. Hopefully its an easy fix (whatever it is)
Old Jun 1, 2006 | 06:04 PM
fsttyms1's Avatar
Hey Maestro,
Yes it is normal for the car to loose some of its pick up and power with the AC on. when the compressor cycles and engages it will cause you to loose some hp. Its most noticable in city driving and will reduce mileage.
If you dont need the AC on simply push the button to turn it off. there is no need to run the ac on all the time.
Old Jun 2, 2006 | 08:39 AM
rezn8's Avatar
You answered my question in your first post. By not using full auto, the AC wont doesn't come on unless I turn it on. Appreciate that...thanks.
Old Jun 2, 2006 | 12:22 PM
acurabum's Avatar
Hey REZN , try to put your climate control in AUTO ... the compressor of my car will cycle and engage less and the car picks up better . Try it ....and keep me posted
Old Jun 2, 2006 | 12:38 PM
fsttyms1's Avatar
Old Jun 2, 2006 | 02:43 PM
rezn8's Avatar
Well according to the thread the AC shouldn't come on at all in Auto unless you turn it on. So far this does seem to be the case. No AC cycling on Auto for me!
Old Jun 2, 2006 | 05:50 PM
bkzjimmy's Avatar
NiGhT rIdEr
if i want the air condition (cold air) to come on i just press the AC button. no one else does that?
Old Jun 5, 2006 | 09:35 AM
acurabum's Avatar
Rezn8 : no .. no ..no ...A/C will engage the compressor in AUTO if the temp that you set is lower then the outside temp.
Old Jun 5, 2006 | 10:10 AM
fsttyms1's Avatar
Only on full auto
Old Jun 6, 2006 | 03:26 PM
antlive's Avatar
Cruiser
$250 for 20 mins >>>>> :X
Old Jul 5, 2006 | 01:41 PM
acurabum's Avatar
Update : I recenly wash/clean my engine and feel my car lost a bit more of it pick up
when the A/C is on .........So I did put a few drop of engine oil at the
A/C compresor pulley to try to lubricate it and amazingly the car pick up smoothly
and drive a lot better when A/C is on .
01CLOwner
Oct 9, 2015 01:07 PM
Rob144
Sep 21, 2015 08:18 AM
lovic87
Sep 15, 2015 06:07 PM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
