VSA and /!\ Light aggravation.
Old Dec 15, 2011 | 08:05 PM
demolition_x's Avatar
Agean Blue Bishes
I have had an issue with one of my wheel sensors after I replaced my front wheel bearings. I had ABS engage and disengage while low speed braking. Took it to my shop and found one of my sensors to be crudded up and too much distance to the cv shaft. I walked to my car and now I have the VSA and /!\ light on. I went back in and they said take it for a ride and see if it goes away.
Little to say that the issue did not go away. So I am planning on going back tomorrow and trying to fight for them to fix all the issues. They charged me 100 bucks to fix the abs problem which I think is fair but this other issue is now a result of them working it. Especially since I was told that all codes were cleared.
What else that could be related to the wheel sensor issue that would keep the light on?
For giggles I went to advance auto and borrowed their OBDII scanner. As usual no codes were picked up with it so I am going to rely on the shop to tell me the issue or what ever they find. I was hoping I could find the code and confirm what they determine to be the issue.
Any where that does scanning for free?
Old Dec 15, 2011 | 09:07 PM
BAGII's Avatar
Autozone scanners won't read ABS and VSA codes, they only read emission codes normally. It sounds like they still have a problem with that wheel speed sensor. I would have them recheck all of the speed sensor gaps at each wheel. The gap should not exceed 1.0 mm.
Old Dec 15, 2011 | 09:41 PM
01tl4tl's Avatar
maybe the other sides sensor is bad too
screw up one side- whats to think the other is right?
Old Dec 15, 2011 | 09:44 PM
Agean Blue Bishes
I dont think it is the wheel sensor issue any more. I dont have abs engaging like i did before. I am pretty confident they fixed the abs issue. I do think this is some thing indirectly related but i guess i will have to find out tomorrow.
Old Dec 17, 2011 | 01:13 AM
BAGII's Avatar
maybe the codes just need to be cleared cause I don't think that they'll erase themselves.
Old Dec 17, 2011 | 01:33 AM
swoosh's Avatar
takin care of Business in
^^^ true....
have you tried resetting the ECU ?
Old Dec 17, 2011 | 01:58 AM
yeedatoy's Avatar
kill you till you die
That would have been the first thing to try besides pressing the VSA button.
Old Dec 17, 2011 | 02:05 AM
yeedatoy's Avatar
Are they coming on every time you start the car?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Rob144
Sep 21, 2015 08:18 AM
bryan zaragoza
Sep 8, 2015 12:28 AM
