very frustrated
very frustrated
i've registered with acura.com with my car i purchased close to 3 years ago. last time i took it in for the srs light the service people were awesome. i purchased my car from ron tonkin honda but brought it to acura of portland. the service manager looks at my car and the vin then says, "oh so you know the service manager over at honda?" i was just like nope, just bought it off their lot. well to the point, it appears that my car did not get serviced for the tranny recall. i was driving around earlier and it seems like the tranny is slipping. i dont wanna end up driving and getting stranded somewhere. and on top of that when i purchased the car the it was not the best experience. itd be a 3 from 1-10. so my car has like 116k miles on it. im wondering if i should call acura directly. i need help though! any advice for me guys? TIA
Serviced for the tranny recall or not it has nothing to do with the slipping trans. That is a completely different issue. What is your question? are you asking if you should contact acura because your trans is slipping? Bring it to the dealer and see if they will help good will any of a trans replacement.
Wont make a difference. The OIL JET is what the recall was for. It was NOT intended to solve the problem with the trans clutchpacks, its for something completely different.
im effin done with this car. acura.com says it was NOT serviced and the dealership now is saying that the tranny was "recalled" and serviced. service manager said i can take it into the shop for drain and fill for $80. can anyone tell me how much 3qts would run me for honda tranny fluid please?
IIRC the trans fluid is around $9 a qt?
You don't want just a single drain and fill, you are supposed to do it 3 times.... drain/fill drive 15 min, drain/fill drive 15 min, drain/fill drive 15 min. Otherwise you are really not changing out most of the fluid by just doing it once... sucks that dealerships sell the 1x drain fill and call that service. Manual says it clearly but dealerships want to charge for 1/3 the service, go figure.
G/L
G/L
Only if they see it on the 2nd gear shaft. Its a VERY rare thing. To this day i still dont believe i have seen a single member with that failure on this forum.
I change mine every 10,000 miles or about every 8/9 months. Tranny still shifts smooth with 123,000 on it. But then it's a 99.
snorf
11-04-2019 06:44 AM
