Timing Belt
Old Jun 1, 2007 | 11:39 AM
atnsx80's Avatar
8th Gear
Timing Belt
I have 120k on my 03 TL-S. I know im way past the recommended timing belt replacement point. Has anyone had their timing belt snap on their vehicle? Any Ideas on the costs and the urgency of this maintenance?
Old Jun 1, 2007 | 01:57 PM
fsttyms1's Avatar
i had 200k on mine and it was still fine. Id still have it replaced if i were you though. Your looking at 600-800 depending on where you go.
Old Jun 1, 2007 | 02:03 PM
Eisenhulk's Avatar
MUCH bigger than you!!
Timing belt breaking = Engine going
Old Jun 2, 2007 | 10:34 PM
raster's Avatar
2 follow up questions.
If the timing belt goes - does the engine just stop, or is it damaged internally requiring engine overhaul?
Has anyone here attempted to change their own belt?
I have to replace my ALT & PS belts and was considering replacing my timing belt and water pump at the same time. 155K on it now.
Old Jun 3, 2007 | 07:44 AM
raster's Avatar
I have found my own answers to post #4.
If timing belt goes out there will be engine damage.
Finally found a post where Southern did his own timing belt.
Now for the fun part - started looking through my car's maintenance records and found that my car had the water pump and timing belt changed at 105K - it now has 155k.
Old Jun 3, 2007 | 03:55 PM
fsttyms1's Avatar
Timing belt breaks motor is due for a replacement or at least a rebuild. If it was done at 105 your fine for some time yet
Old Jun 7, 2007 | 03:35 PM
killer_acura's Avatar
killler_99_TL
my 99 tl has 144xxxkm's and i still havent changed my timing belt...but i checked it..it still looks fine though
Old Jun 7, 2007 | 04:25 PM
fsttyms1's Avatar
So you took the time to take off all the covers and inspect the belt but didnt replace it? Age is more of a factor than miles on rubber belts
Old Jun 8, 2007 | 10:08 AM
harminder247's Avatar
:( Harminder Is Lost In
i have a real quick question, im on my way to drop off my car for the 105k tune up and im beng charged 225 to put in the water pump, timing belt, ac belt and power steering belt. I paid 139 for timing belt and water pump and 38 for the other two belts. Does this seem about right? Im planning on doing the brake fuild, spark plugs myself. Does about 400 seem like a good price and oh yeah this is at a private mechanic my dad knows. BTW wat kind of brake fluid should i use? thanks.
Old Jun 9, 2007 | 05:20 AM
SRSEN1999's Avatar
3rd Gear
Re: Timing Belt
Wow, 120K on your timing belt? Dude, you are really pushing it. I was very worried that I didn't change mine until after 90K and I live in Phoenix where it's hot half of the year.
I have a '99 3.2TL by the way.
Old Jun 9, 2007 | 08:07 AM
fsttyms1's Avatar
Its not like they just all of a sudden hit 100k and break. I had 200k on mine and laying side by side with the new one you could hardly tell teh difference.
Old Jun 10, 2007 | 02:40 AM
TL_Fo_Life's Avatar
My "P" SpAnKs YouR "S"
Seems pretty reasonable. The 400 bucks is much better than spending 800 or more for a busted timing belt and bent valves. BTW 120K is not that bad, but get it done soon.
Old Jun 10, 2007 | 03:09 AM
well it cost me 570 for a timing belt, water pump, ac belt, power steering belt, spark plugs and motor mount, the top right, did that myself everything was done by the mechanic and labor was only 265.so finally its done
Old Jun 13, 2007 | 02:13 AM
killler_99_TL
i dono how to open that shit up...i just looked at the belt from outside and it looked fine...on the owners manual it sayz to change it at 168000 KM and mines only at 144xx right now but it makes this sound when i start it up an especialy if i drive near a wall...you could telll its the sound of like somthin rotating....an to top all this of...i just baught this car like a week ago from a couple....
Old Jun 13, 2007 | 08:28 AM
fsttyms1's Avatar
You cant see the timing belt without removing all the covers. What you looked at was most likely the Alternator and Power Steering belt.
Old Jun 14, 2007 | 04:57 PM
derrick's Avatar
^ '99 TL and at 144 xxx km? Change it for peace of mind. Obviously, you don't know what you're looking for (exactly) so you're better off taking it to a mechanic to get the timing belt changed. Better safe than sorry.
vaughanml2
Nov 1, 2021 10:16 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
