throttle positon sensor gone bad???
Team Nighthawk Member
i just installed a v2 not too long ago, i had it on for about 3 weeks and now my engine check light came on. so i got it obd2 and it says im gettin low reading. help i called da dealer n they said i gota buy a new tb
SSTS
Originally Posted by SatinSilverTypS
well if it says you have a low TPS reading then you can always remove it and test it yourself with a DVM. a TPS shouldn't cost too much so i don't see why you couldn't get one and put it on yourself. the idea that they told you to buy a new throttle body bothers me.
SSTS
SSTS
ok but wat sensor is it? if ur openin the hood i see 1 on top 1 one side and 1 on bottom? and i was told dat it has screws and wats a dvm? da dealer said dat it aint sold seperatly and ill have to buy a new tb at 500 and some change. but if i can take it out and run a test then i will do dat. thanks guys oh again wats a dvm?
Jul 16, 2017 07:33 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
