Throttle Body
Throttle Body
DEALER SAID CHECK INGINE CODE (PO122) MEANS I NEED A NEW THROTTLE BODY. DEALER QUOTED 498.00 FOR JUST PART! CAN SOME ONE GIVE ME SOME ADVISE. JUST BUY PART FROM THEM OR AFTERMARKET IF ANY? THANK YOU WHO EVER IN ADVANCE.
Originally Posted by NSXNEXT
P0122 indicates a problem with the throttle position sensor. It can be replaced without replacing the entire throttle body. It's an easy DIY.
Originally Posted by honda_inspire99
yea definately try to do it yourself, it might be hard to get off because its revitted on ther but it can be done
Then I have no idea what I'm talking bout. I'm thinking of the map sensor
Originally Posted by TLONTWENKIES
Also Dealer Told Me You Cant Just Buy The Sensor. Is This Not True?
Originally Posted by jleon2516
Map sensor can be replaced, the TP sensor can not be removed, if your TP sensor goes you need a new throttle body.
http://cgi.ebay.com/ebaymotors/1999-...28864531QQrdZ1
there is one for $150 way cheaper than the dealer the whole throttle body with all the sensors
fsttyms1,
I think you are the Guru here so I want to ask you this question:
Do you think getting aftermarket spacers from www.outlawengineering.com is worth it?
Thanks!
Thanks!
Originally Posted by Jamesmoore
fsttyms1,
Thanks!
Thanks!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
