stuck in manual mode
Old Jan 26, 2009 | 02:25 AM
lilpablo's Avatar
IN MY TL
i have a 99 tl with 01 swap in it and it is stuck in manual mode i can reverse it and go into all the gears just wont go into automatic mode HELP
Old Jan 26, 2009 | 02:41 AM
8800honda's Avatar
What computer are you using? Any check engine code?
Old Jan 26, 2009 | 04:48 AM
Rajca's Avatar
wham bam thank you ma'am
check your sensors that they are all plugged in. and what ecu r u using? do u still have the 4spd or the 5spd?
Old Jan 26, 2009 | 09:05 PM
lilpablo's Avatar
IN MY TL
5 spd ecu harness shifter box everything where are the sensors located
Old Jan 26, 2009 | 10:08 PM
fsttyms1's Avatar
Do you have the 5 speed ECU?
Old Jan 26, 2009 | 11:08 PM
lilpablo's Avatar
IN MY TL
yes
yea everything 01 and 5 spd
Old Jan 26, 2009 | 11:20 PM
Rajca's Avatar
just making sure but u also have the 5spd trans? id check the connection again.
Old Jan 26, 2009 | 11:22 PM
rob-2's Avatar
has it been like this since the swap? If not whats changed?
Old Jan 27, 2009 | 03:09 AM
lilpablo's Avatar
IN MY TL
yea since it was put in
Old Jan 28, 2009 | 05:04 PM
lilpablo's Avatar
IN MY TL
so i went to acura and they are thinking its a connection hopefully this will only run me a couple hundred bucks
Old Jan 28, 2009 | 06:51 PM
fsttyms1's Avatar
It has to be a connection. If you swapped the wiring, ECU/trans/motor etc that's really all it can be. I dont think the engine compartment to cabin harness are different or would cause that, nor should the under hood relay center. Either that or the trans is bad?
Old Jan 29, 2009 | 09:25 AM
lilpablo's Avatar
IN MY TL
cool and i will let you guys know whats up with it i drove the car the swp was in before and it drove fine
Old Jan 29, 2009 | 09:53 AM
fsttyms1's Avatar
then i would unplug and look at all trans connections and make sure all pins are straight. make sure every thing is plugged in fully to the trans.
Old Feb 3, 2009 | 12:44 AM
lilpablo's Avatar
IN MY TL
okay i have been too busy to take my car to acura so maybe saturday i'll let you guys know. i did however finally get a chance to pull the eclipse out so thats cool
Old Feb 3, 2009 | 10:25 AM
phee's Avatar
I got the Shifts
looking forward to hearing whats up
Old Feb 12, 2009 | 09:55 PM
lilpablo's Avatar
IN MY TL
d5 flashing
just notice this any ideas
Old Feb 12, 2009 | 10:15 PM
twistedwedge's Avatar
6MT Someday..
CEL on?
Old Feb 13, 2009 | 07:03 AM
fsttyms1's Avatar
Can you get the codes read?
Old Feb 13, 2009 | 11:34 PM
lilpablo's Avatar
IN MY TL
finally back at acura lea mechanic working on my car every single light was on tcs abs srs cel but thankfully the tranny is good just an electrical connection should be done monday
Old Feb 16, 2009 | 10:42 PM
lilpablo's Avatar
IN MY TL
so i got my call about my car today it needed a tranny solenoid all SHOULD be well $435 bucks parts and labor
Old Feb 17, 2009 | 06:14 PM
lilpablo's Avatar
IN MY TL
so i picked up the car today and it runs great now i have one more problem the only lights that work on my car brake lights work and head lights but parking lights dash lights and taillights are out fuses are all good that i found
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
hashbrown
Sep 29, 2015 12:13 PM
