Starter??
Starter??
Wife just called and said she stuck at the salon. She said the car will not start. The starting issues didn't sound like the battery because the warning light sound strong when she is cranking. Didn't sound like a dying battery. If its the starter, what are some tricks used to get a quick start. Is it ok to tap the starter? Help me.
its not really ok to tap the starter but it does work, and its only the starter if you one solid click when you try to start the car, if you hear a repetitive clicking then your battery is low, or you have a bad connection, if you hear a grinding noise the starter is messed up and usually some other parts along with it
so it IS cranking over?
sounds like normal cranking speed?--dash lights and warning sounds mean nothing
the starter draw is mega amps- thats why the battery has many!
The green key sign on dash works?
and if jumped off running car?
make sure to ground neg jumper cable to bad TL- to strut bolt or other ground point
NEVER hook the batteries together!! a short in the bad car can take out the good cars electrical system!
How old is your battery--more than 3-4 years?
beyond that- and the normal things- egr system cleaned--more than 75kmiles on it since last cleaned? will cause start/idle run probs
Spark plug age- correct ngk if recent change?
ck ignition fuse, fuel pump fuse
battery cables, especially main ground from batt, and small grounds from frame to engine- all must be in good condition
crud reduces their abilty to ground the system, no ground= no spark
parts stores are happy to come out and run a FREE system test on the batt- alt -cables
it cks battery abilty to take a load and recover, alt output amps-with lights on
and amp draw from starter on its use
excess amps there mean starter is going out
Yes and no...starters are one of the hardest thing basically if it starts without making grinding noises your pretty much safe, draw when trying to start could be dirty fuel system, bad spark plugs, even a bad crack sensor, anything that makes cracking take longer will show up as excess amp draw, when you get one solid click from the starter then start shopping for starters
I prefer to use an engine lift block/plate as the ground when available,,but the strut tower is close and clean
there is always a chance of shorting the battery in the good car if a major prob in the dead car,,,never jump start a strangers car pos to pos and neg to neg
use alternate ground on dead car
its old school thinking but it still applies..protect my stuff,,fix your stuff
Engine lift plate... great. Strut tower... still a bad idea; why risk the damage? Old school? Battery to battery as I was taught, last connection on the dead car negative terminal. I still do it that way a lot; blow off the battery top with a few strong breaths to dispel the hydrogen and turn my face away just in case. Fingers crossed.
I just don't like aftermarket products. Although the price is attractive, the quality is sometimes terrible. The guy at Autozone was trying to sell me a Duralast for $114. Called Acura and the have one for $214. Has anyone had bad luck with aftermarket? Do you trust aftermarket?
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
