"Small Light" Fuse keeps blowing
Old 05-21-2012, 07:42 PM
MechEng
03tLsNBP's Avatar
I just recently installed a new head unit, and that night I go to turn the lights on and boom, the "small light" fuse blows. So I replaced the fuse and it just blew again when I turned the lights on.
Why would the "small light" fuse keep blowing? I double and triple checked all the wiring that I did and it's all fine. No exposed wires. And I didn't even go near anything that would be on the "small light" circuit. I just don't understand.
Is there a wiring diagram of everything that is on the "small light" circuit? Anyone have any other ideas?
Old 05-22-2012, 12:21 PM
MechEng
03tLsNBP's Avatar
Well it looks like it is the head unit harness. I still don't know where I went wrong in the wiring though. I guess I will explore more.
Old 05-22-2012, 12:57 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Its in your wiring im guessing. Id look at what you have connected to the radios dimmer wire.
03tLsNBP (05-22-2012)
Old 05-22-2012, 06:54 PM
MechEng
03tLsNBP's Avatar
It was the dimmer/illumination wire on the harness that was causing a problem. You were right. I couldn't figure out how it was wired incorrectly but it doesn't matter because everything still works fine with it disconnected.
Thanks fstty!
Old 03-02-2019, 05:41 PM
Jt Tran's Avatar
Thanks fstty!
hey im have that same problem i was hope u can help me locate the wire?
Old 03-04-2019, 05:07 AM
Iggy's Avatar
Looks like the red wire off the head unit goes to the brightness control.
tsx_boy
12-13-2019 08:33 PM
Acura604
20
08-05-2017 12:55 AM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
hashbrown
09-29-2015 12:13 PM
ripit
09-26-2015 06:19 PM
Quick Reply: "Small Light" Fuse keeps blowing
