"Small Light" Fuse keeps blowing
MechEng
I just recently installed a new head unit, and that night I go to turn the lights on and boom, the "small light" fuse blows. So I replaced the fuse and it just blew again when I turned the lights on.
Why would the "small light" fuse keep blowing? I double and triple checked all the wiring that I did and it's all fine. No exposed wires. And I didn't even go near anything that would be on the "small light" circuit. I just don't understand.
Is there a wiring diagram of everything that is on the "small light" circuit? Anyone have any other ideas?
Its in your wiring im guessing. Id look at what you have connected to the radios dimmer wire.
03tLsNBP (05-22-2012)
MechEng
It was the dimmer/illumination wire on the harness that was causing a problem. You were right. I couldn't figure out how it was wired incorrectly but it doesn't matter because everything still works fine with it disconnected.
Thanks fstty!
Thanks fstty!
hey im have that same problem i was hope u can help me locate the wire?
Acura604
20
08-05-2017 12:55 AM
ripit
09-26-2015 06:19 PM
