SB#02-006: Seatback Panel Loose or Detached
Here is a common problem with our cars. Some of you probably have heard about this service bulletin, it came out in 2002. Some may have no idea about it or some are wondering how to fix your seatbacks when your out of warranty.
There is a kit sold at Acura that we use. You can purchase it from there. Just note to the parts guy that it is apart of a service bulletin. They should stock the part.
Here is a link to the REAL REPAIR PROCEDURE:
http://www.in.honda.com/Rjanisis/pubs/SB/b02-006.PDF
Good Luck.
Good Luck.
Sweet, i actually need to do that
Now to get that kit
Unregistered Member
It was a bracket or something that would be installed on the bottom of the seat-backing. Worst case scenario, ask your dealership to print it out for you.
takin care of Business in
Received 4,732 Likes
my driver side seat does it too....does this apply to the 2005's ?
i had it replaced when i had warranty (80K miles back)....it happened again after my warranty ran out but they were charging me an arm and leg to get it fixed....
well i hope they fix it for you fellas...waiting for the pix of the fix...
Hi all...I did not see any responses on how to fix the listed issue. I have 2000 TL and the passenger seat back has fallen off. I took it to the dealership and they want $120 to fix it. Any assistance with the fix and parts details will be greatly appreciated.
spartacuss (09-19-2012)
ITSJESTER
17
12-06-2018 02:29 AM
dainmezron
10-16-2015 06:56 PM
