ECU Codes for 99-01 TL's
Old Dec 24, 2005 | 08:20 PM
honda_inspire99's Avatar
Skeet Skeet Skeet
Here are the Ecu codes for 99-01 TL i'm not sure if there is another post on this so i thought i would post it up. MOds please make this a sticky if there isn't another post with the codes
99–01 3.2TL & 3.5L MDX
OBD2
MIL
P0107
MAP Circuit Low Input
P0108
MAP Circuit High Input
P0112
IAT Circuit Low Input
P0113
IAT Circuit High Input
P0116
86
ECT Circuit Range/Performance
P0117
ECT Circuit Low Input
P0118
ECT Circuit High Input
P0122
TP Circuit Low Input
P0123
TP Circuit High Input
P0131
Sensor 1 Primary HO2S Circuit Low Voltage
P0132
Sensor 1 Primary HO2S Circuit High Voltage
P0133
61
Primary HO2S Slow Response
P0135
41
Primary HO2S Heater Circuit Malfunction
P0137
63
Secondary HO2S Circuit Low Voltage
P0138
63
Secondary HO2S Circuit High Voltage
P0139
63
Secondary HO2S Slow Response
P0141
65
Secondary HO2S Heater Circuit Malfunction
P0171
45
System Too Lean
P0172
45
System Too Rich
P0300
Random Misfire
P0301
71
Cylinder 1 Misfire
P0302
72
Cylinder 2 Misfire
P0303
73
Cylinder 3 Misfire
P0304
74
Cylinder 4 Misfire
P0305
75
Cylinder 5 Misfire
P0306
76
Cylinder 6 Misfire
P0325
23
KS Circuit Malfunction
P0335
CKP Sensor Circuit Malfunction
P0336
CKP Sensor Range/Performance
P0401
80
EGR Insufficient Flow
P0420
67
Catalyst System Efficiency Below Threshold
P0451
91
Fuel Tank Pressure Sensor Circuit/Range Performance
P0452
91
Fuel Tank Pressure Sensor Circuit Low Input
P0453
91
Fuel Tank Pressure Sensor Circuit High Input
P0505
14
IAC System Malfunction
P0715, P0720, P0730, P0740, P0753, P0758 & P0763
70
A/T System Malfunction
P1106
BARO Sensor Circuit Range/Performance Malfunction
P1107
BARO Circuit Low Input
P1108
BARO Circuit High Input
P1121
Throttle Position Lower Than Expected
P1122
Throttle Position Higher Than Expected
P1128
MAP Lower Than Expected
P1129
MAP Higher Than Expected
P1259
22
VTEC System Malfunction
P1297
20
ELD Circuit Low Input
P1298
20
ELD Circuit High Input
P1361
TDC Sensor Intermittent Interruption
P1362
TDC 1 Sensor No Signal
P1366
58
TDC 2 Sensor Intermittent
P1367
58
TDC 2 Sensor No Signal
P1456
90
EVAP System Leak Detected (Fuel Tank System)
P1457
90
EVAP Control System Leak Detected (Control Canister System)
P1491
EGR Valve Lift Insufficient Detected
P1498
EGR Valve Lift Sensor High Voltage
P1519
14
IAC Valve Circuit Failure
P1607
ECM/PCM Internal Circuit Failure
P1676
35
FPTDR Signal Line Failure
P1678
35
P1656 P1705, P1706, P1709, P1738, P1739, P1753, P1768 & P1773
70
Old Nov 3, 2011 | 01:01 AM
NFSKING2FST4U's Avatar
There is a transmission recall on these Acura models, mine decided to go bad recently w.o. warranty after 5 years since the original owner replaced the transmission in 05 through Acura with warranty. I took it to a highly rated shop in my area. $3400 later A remanufactured Trans was put in, a week later I got check engine P0132 causes my car to have poor gas mileage and to lose power for about 30sec where the car just rolls and wont respond to accel. loses power like it wants to stall, then suddently power returns and happens intermittently as I drive. Same shop wanted to charge me $500 for o2 replacement. Ive been riding it out until I get a chance to lift the car and inspect wiring etc. meanwhile discovered my AEM cold air intake pipe had a hole on it somehow, so I cleaned intake system and converted to short ram with new filter and reset battery/deleted code however P0132 persists, now with intermittent TCS light. Lastly My Viper791xv alarm system wont chirp/sound off anymore even if I open a door with alarm enabled, since door lock/unlock and remote start functions are working. All of this has occurred since the trans. job. The shop claims not messing with alarm sys. or intake sys. Hmmm. :/ any input on either matter would be greatly appreciated. Thank you.
Old Nov 3, 2011 | 11:05 AM
01tl4tl's Avatar
your understanding of the trans warranty and recall is flawed- most but not all cars got 7year 9month/109kmile warranty-
doesnt matter if trans replaced under warranty several times
At this point in time and or miles, you are past the limits right?
3400 for a rebuild!!! and they screwed up other stuff, plus the trans wont shift=
needs to go back - could be a simple wiring switch or a major flaw in the rebuild
Or take it to another shop for an opinion- quick!!
Old Nov 3, 2011 | 11:09 AM
01tl4tl's Avatar
you may need a front O2 sensor- could have been damaged or the wire for it messed up~
mileage drop would point to that, and back up the code
easy diy or any shop= NOT 500 dollars!!!
buy a Denso brand- thats the OE maker, so plug and play part, dont have to buy at dealer, any parts store sells them
reset ecu by pulling the CLOCK fuse on passenger end of dash for a minute
forces master reset and relearn/self test/new parts learn
Old Nov 3, 2011 | 11:10 AM
01tl4tl's Avatar
kudos for a diligent search to find a 2005 thread with codes!
they are also listed in our diy section
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
TypeS860
Jan 10, 2026 11:11 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
