2003 TL Headlight Dead
Old Oct 31, 2011 | 09:35 PM
markhamr's Avatar
Hi, new to the forums...picked up a 2003 with 50k miles about 3 months ago and two or three weeks ago the maint light when on.
Last night, the right headline flickered when I turned them on, then went pink and subsequently died altogether. From what I have read, it seems like I only need to replace the bulbs. Is that correct or should I look at one of the full kits? I'd prefer to do just the bulbs unless there are any big drawbacks.
What type of light should I buy and where from for a good deal? I had seen in a previous thread mention of a sponsor sale. Anything similar still going on or likely to happen soon?
Thanks!
Old Oct 31, 2011 | 09:39 PM
markhamr's Avatar
Also, how in-depth is the install process for replacing the bulbs or the full kit?
Old Oct 31, 2011 | 09:50 PM
fsttyms1's Avatar
All you need is the Bulbs. Stock K is 4300. Stick with that to 5k. Nothing else will be as bright. Check our vendors for good deals on bulbs.
As for the Maint req light being on, the how to reset it is in the manual or in our DIY thread
Old Nov 1, 2011 | 03:31 AM
01tl4tl's Avatar
mait light is simply the oil change reminder, which works off `miles since last reset`
not a guage of oil condition
awesome bulbs- kaixen 100+ a pair
cheap but work www.hidextra.com
mention acurazine when talking to anyone
Old Nov 4, 2011 | 03:23 PM
neptune07's Avatar
6th Gear
just out of curiousity, one of the oem part states 4000 kelvin, that would work fine? maybe a little brighter as i have to change mine as well, as need to go ahead and get two while i am at it where they will match, also do you recommend going with the ebc ceramic and kevlar pads instead of factory replacement as i have been known to make panic stops at times, any decent reasonably priced rotor to suggest, any help in this matter would be most welcomed
Old Nov 5, 2011 | 12:13 AM
blaine209's Avatar
Id get the 6000k at hidpalace. If you want a long lasing buld get phillips bulb trust me you wont regret it
Old Nov 5, 2011 | 12:14 AM
blaine209's Avatar
I mean bulb.Amazon has good ones also.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Pham Alvan
Mar 16, 2016 09:17 AM
Mr.Tea
Oct 2, 2015 10:32 PM
