Removed Exhaust Resonator - Threw a 02 Sensor Code!!
Old Jul 9, 2007 | 10:47 AM
oulaw29's Avatar
Attorney- Will Sue 4 Food
Well @#%^&@$#% if i didnt remove the large resonator (small already removed) on the exhaust at muffler king, and the next day my car engine light went on. I went to jotech who read a 02 sensor code and re-set it. 5 min later it lit up again. Before going to jotech i diconnected the battery. Dammit i have inspection out next month. Anyone know what i need to look for??
Old Jul 9, 2007 | 12:19 PM
MurdaZ's Avatar
well u can take it off and use carb cleaner for a temp fix, removing the resonator shouldnt of triggered it, buts probably its time.....also is it the front or rear 02 sensor?
Old Jul 9, 2007 | 12:37 PM
EL19's Avatar
jus get an o2 sensor simulator ull pass inspection with that
Old Jul 9, 2007 | 03:58 PM
fsttyms1's Avatar
removing the resonator didnt cause the 02 sensor to go bad. Did the place or you let the exhaust fall enough to damage the o2 sensor??
Old Jul 9, 2007 | 04:39 PM
oulaw29's Avatar
not that i could tell. I was right there and they had two different adjustable holders holding up the exhaust. what does the o2 sensor look like so i can tell if its cut/damaged. Also where can i get a device to simulate the o2 sensor. I gotta pass inspection.
oulaw29's Avatar
Old Jul 9, 2007 | 06:10 PM
fsttyms1's Avatar
there are 2 of them. Both attach to the exhaust. 1 before the cat and one on the cat. You need to find out what sensor it is. There isnt much to look at to see if there is damage unless you can see a damaged wire. Finding simulators is harder to do. Its illegal to run. Find out which o2 is bad or throwing the code, inspect it/replace it.
Old Jul 11, 2007 | 09:21 AM
EL19's Avatar
jus search for o2 simulators on ebay theres a lot of em on there...they are illegal to have though btu you'll pass emissions
Old Jul 11, 2007 | 03:14 PM
BustedLX's Avatar
What's the code number it threw?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
ibGTV
Sep 28, 2015 03:40 AM
