Rear window regulator
Rear passenger side electric window is not working correctly, still life in the motor but the window has dropped down and won't come back up. I'm assuming I need a new regulator (I've done a couple before on different makes), my main question is will a 2002 Accord regulator work in the Acura?
yup new regulator should fix that right up
GO to https://www.oemacuraparts.com/ and type in your car
then go to https://www.hondaautomotiveparts.com/ to put in a 2002 Accord
compare part numbers
