Project Car
Old Jul 18, 2011 | 03:44 PM
hotboxspacecraft's Avatar
Project Car
I finally reach enough money to buy a dark emerald pearl acura touring luxury 2000 model I'm aware of all the problems it comes with so I'm here to begin fixing with the help of Leo Honda, Miami FL.
The car is at the shop now for inspection and this is the list he gave me for everything to be in 99%!
- Brake pedal pad $25.00
- Right front door lock actuator (original part & labor) $120.00
- Right rear door lock actuator (original part & labor) $120.00
- Transmission service $45.00
- Oil change $25.95
- Rear motor mount (original part & labor) $305.00
- Timing belt service (water pump, timing belt, cam seals, crank seal, oil pump seal, oil pan gasket, vtec gasket, solenoid gasket,
oil, filter, serpentine belt) (original parts & labor) $740.00
- Rear main seal (original part & labor) $445.00
- Valve cover gaskets & rear cylinder head orings (original parts & labor) $275.00
- Clock assembly (original part & labor) $160.00
- Rearview mirror assembly (original part) $120.00
Now speaking about the engine as you see it haves a lot of problems..
so I have been thinking should I just swap out my J32A1 engine with a J32A2 from type s model?
I look a lot into cars but I have little mechanic experience so this site have been a great guide for me to get my car the shape I want it to be (;
Old Jul 18, 2011 | 03:52 PM
PShep's Avatar
Your rear main and head covers are leaking? Why do you need a new clock?
Old Jul 18, 2011 | 04:11 PM
yes and my clock stopped working completely is wasn't a blown fuse :/
Old Jul 18, 2011 | 04:16 PM
my.daily'tl''s Avatar
Always Working In
$1765 alone on engine work? You can get a new(used) engine for less than that with all the trimmings.
Old Jul 18, 2011 | 04:17 PM
jjashaa's Avatar
Avant Garde Wheels
heres what i think....
Originally Posted by hotboxspacecraft
- Brake pedal pad $25.00 -- do it yourself
- Right front door lock actuator (original part & labor) $120.00 -- go to junkyard, find from salvaged
- Right rear door lock actuator (original part & labor) $120.00 -- go to junkyard, find from salvaged
- Transmission service $45.00 -- what's included in this transmission service
- Oil change $25.95 -- do it yourself..
oil, filter, serpentine belt) (original parts & labor) $740.00 -- you can do some of these by yourself... and you have oil and filter on here again... oil change twice at once?
- Clock assembly (original part & labor) $160.00 -- go to junkyard, find from salvaged
- Rearview mirror assembly (original part) $120.00 -- go to junkyard, find from salvaged
as for motor work.. at this point.. i'd look for a type-s motor and 6spd trans and do the swap.....
Always Working In
you must be getting a new clock. id just as well get one from a junked vehicle.
Old Jul 18, 2011 | 04:41 PM
how much do type s engine and 6 speed transmission go for? it cost me $1765 to fix the engine I rather just do that..
Old Jul 18, 2011 | 04:42 PM
yeah is a new oem clock it wont be me putting the clock in is the mechanic where my car is at who's replacing it
Old Jul 18, 2011 | 07:07 PM
01tl4tl's Avatar
bet he has never worked on a TL-that trans service,,, timing belt list has everything but the tensioners--which are very important
Do you already own this car or can you run from it still?
Old Jul 19, 2011 | 02:07 AM
I purchase the car last valentines day
Old Jul 19, 2011 | 02:24 AM
KatabaticSaint's Avatar
Engine swap for sure cls 6speed swap I'd look for one with the 90k service done timing belt water pump etc.
Old Jul 20, 2011 | 12:56 PM
it will cost me $2,400 firm to change the engine to a type s how much will the 6 speed lsd transmission cost included O.O?
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
jordanboi
Sep 5, 2015 01:33 AM
Sep 4, 2015 08:03 AM
