Problems after header installation
Old Apr 9, 2007 | 09:18 AM
dmbodine41's Avatar
Master Baiter
Alright everyone, I installed Nopi headers in my 03 tl on Sat. and am experiencing some problems:
1. I have never had headers installed on any vehicle I have owned. When I hit the gas I am hearing a high pitched noise that I am assuming is a leak. Here's the question...How do I find the leak and what do I do to fix it?
2. My engine, maint., and tcs lights are now on. I would guess the engine light is on because the sensor was not reinstalled (it would have rubbed on the oil pan and all of the wires would have been cut in time), but what about the other 2? I know everything is functioning correctly, so is there any way to turn these off?
Old Apr 9, 2007 | 10:36 AM
fsttyms1's Avatar
So you didnt install the 02 sensor, your hearing a leak and your lights are on? It sounds like all are a cause of the O2 not being installed. That has to be installed.
Old Apr 9, 2007 | 10:45 AM
dmbodine41's Avatar
Master Baiter
if that's the case, is there a sensor that's about 2" shorter that can be used? there just isn't enough room for the stock sensor to fit without rubbing on the oil pan.
Old Apr 9, 2007 | 11:22 AM
NSXNEXT's Avatar
Unfortunately no. The only rememdy is to have a muffler shop move the 02 sensor bung to the correct location. This is a common problem with one brand of headers (I think it's OBX).
Old Apr 9, 2007 | 07:39 PM
dmbodine41's Avatar
Master Baiter
sweet!! that sounds simple enough.
i talked to a guy that has put headers in his ride before and he said the noise i thought was a leak is actually the force of the air hitting the cat. so, the obvious question is.........any suggestions for a high flow cat and/or a cat-back system?
Old Apr 14, 2007 | 11:22 AM
dmbodine41's Avatar
Master Baiter
ok, i got the o2 sensor moved...$43.00 at a custom muffler shop. this turned off the tcs light but the engine light is still on. any suggestions? is there a way to turn it off similar to the maintenance light?
Old Apr 14, 2007 | 10:46 PM
orgnlprankster7's Avatar
08 Civic SI
unplug the battery for 20 min to reset the ECU then see if it comes back
Old Apr 15, 2007 | 05:18 PM
dmbodine41's Avatar
Master Baiter
alright, everything is working properly now. thanks for your help everyone.
Old Apr 15, 2007 | 07:53 PM
fsttyms1's Avatar
Pull the clock backup fuse next time. Its easier.
cycdaniel
Dec 17, 2019 10:58 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
NSolace
Sep 3, 2015 08:02 PM
