Powerslots and noise?
Old Mar 28, 2006 | 11:00 PM
Got_3.2?'s Avatar
hey i got slotted powerslot rotors in the front with hawk hps pads. Had them on for about 4 months. the last 2 weeks they have been screaching loud. what can this be caused by and how can i fix this? im thinking it could be brake dust but what else could it be?
Noise is really embarassing lol
Old Mar 29, 2006 | 09:26 AM
RickRoush03's Avatar
RickRoush03
check your pad thickness along with you may need to add some anti brake squeal stuff to back of the pad.
also, the pads you have are more agressive then standard pads and may need more heat in them to stop the squealing. i had the hps plus on the stang and then the hps, they always squealed but not so much the hps
Old Mar 29, 2006 | 10:09 AM
Got_3.2?'s Avatar
where can i get this anti squeal stuff and what brand should i get?
Old Mar 29, 2006 | 10:37 AM
burn-one's Avatar
It should come with your pads, but if not you can pick it up at any automotive shop for like $1 per package.
Old Mar 29, 2006 | 12:12 PM
fsttyms1's Avatar
You can get it at all parts stores. Most likely most of the nose is coming from teh more aggressive pad. Also check the thickness of the pads while your putting the anti squeel on
Old Mar 29, 2006 | 07:56 PM
RickRoush03
i will say on my hps plus pads they lasted about 10k and gave off loads of brake dust and ate my new rotors like they were nothing. the hps's helped a little on the dust part.
Old Mar 29, 2006 | 08:31 PM
flydog's Avatar
Make sure the anti squeal stuff goes behind the pad wherever there is metal to metal contact with the caliper. Do not apply it to the face of the pad or the rotor itself. It seems stupid but to most people its reasonable the noise comes from the rubbing of the pad on the rotor so they feel thats where it goes.
Old May 19, 2006 | 12:22 AM
Got_3.2?'s Avatar
update. i brought my car in to get the brakes checked and they lubed it up but the rubbing noise is still there mostly coming from the passenger side. when i made right turns it makes a big squessy noise. the mechanic said its from the rotor being slotted that the pad is hitting the groove causing the noise. i dont think so ne more suggestions??? i hate these noises makes me not want to drive the TL ne more.
Old May 19, 2006 | 01:59 AM
Most likely coming fromt the pads I think. My bro has Hawk pads on his Civic and they squeak. I have Akebono Ceramics and they are queit but the Rotora Slotted rotors have a hum to them at moderate to heavy braking which I learned to live with.
Old May 19, 2006 | 08:38 AM
fsttyms1's Avatar
Id say ditch the pads and get new ones. Slotted rotors should cause a hum while moderate brakeing but not screatching. Try switching to a different pad
Old May 19, 2006 | 11:39 AM
Got_3.2?'s Avatar
which pad should i go with?
Old May 19, 2006 | 12:39 PM
fsttyms1's Avatar
Akebono, satisfied, or EBC (either the Green stuff or there new OEM replacement pad)
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
