Parking lamps and tail lights wont work!!!!
Old Apr 26, 2007 | 11:18 PM
eldoman545's Avatar
6th Gear
The problem is with a 2000 3.2 TL. I replaced the dash light dimmer switch and now my dash lights, the parking lamps (running lights), and the tail lights wont work. The brake lights still work. I tried to find the fuse but couldnt find which one it was. Anyone who might have an idea what fuse this could be or with an answer to the problem please help.
Old Apr 27, 2007 | 01:27 AM
RyanOfSoCal's Avatar
2nd Gen. TL Looks Best!
I have a similar problem. I verified all fuses on both side and under the hood are good. Help!!
Old Apr 28, 2007 | 02:15 AM
tientruong's Avatar
02' 3.2TL-s /w NAVI
check for a short in the wires that you worked with.
also, Check your fuses,
Old Apr 29, 2007 | 06:34 PM
eldoman545's Avatar
6th Gear
I was Looking for a parking lamp fuse or running lamp fuse but i was unable to find either one. So i just started testing them with a test light and came across a fuse underneith the hood. This fuse was marked as SMALL LIGHT i replaced this fuse and all of my nonworking lights started working. So if you are currently having this problem replace this fuse even if it doesnt look blow this could solve the problem.
Old Apr 30, 2007 | 12:28 AM
I'll try tomorrow and update. Thanks!
Old May 1, 2007 | 01:24 AM
replaced that fuse with no luck...Can you recall if you did anything else?
I'll go to RadioShack tomorrow to purchase a fuse tester and test all fuses.
Thx...Ryan
Old May 1, 2007 | 02:08 AM
MurkyRiversTL's Avatar
COTM Coordinator
The fuse is in the engine bay fuse box. The fuse is called "small lights" or something similar to that.
Old May 2, 2007 | 12:43 AM
Correct...that's the fuse I replaced.
Old Dec 29, 2019 | 03:00 PM
Keilasacura's Avatar
6th Gear
i got same issues
did u find the issue
Old Dec 29, 2019 | 03:01 PM
6th Gear
me too anything on the solution??????
any luck ?????
Old Dec 30, 2019 | 07:43 PM
Iggy's Avatar
This thread was from 12 years ago. Doubt you'll get an answer.
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
theinsvnity
Sep 10, 2015 10:22 PM
brjones9
Sep 3, 2015 07:30 PM
