overfilled oil
Old Jan 31, 2012 | 02:15 PM
Type-ES's Avatar
overfilled oil
I do my oil change run the car, turn it off, check the level its right on the upper dot. If I check the oil a few days later its over filled. I've tried making sure I only get it to the line but some how it ends up overfilled. I've never had this problem before with any of my cars . Anybody else have this problem? Normal? Tips/tricks?
Old Jan 31, 2012 | 02:38 PM
swoleCL's Avatar
¿baCon?
Overfilling can screw with the pressure in the engine. Not very smart
Old Jan 31, 2012 | 03:01 PM
Type-ES's Avatar
Basic knowledge.
That's not what I asked. Thank you.
Old Jan 31, 2012 | 05:59 PM
HEAVY_RL's Avatar
Oil is running from the valve cover to the pan, that takes time.
When you checked the oil a few days later was the engine hot or cold?
How far was it over?
Did you pre-fil the oil filter?
Old Jan 31, 2012 | 06:02 PM
fsttyms1's Avatar
How much oil are you adding after you drain it and put a new filter on.
Old Jan 31, 2012 | 07:19 PM
Type-ES's Avatar
Around 4.3-.5 quarts
Old Jan 31, 2012 | 09:05 PM
yeedatoy's Avatar
kill you till you die
You checked the oil level after you just ran the car, or am I misunderstanding this?
Old Feb 1, 2012 | 05:53 PM
01tl4tl's Avatar
only reliable reading is cold or left sitting 15+ minutes after running
while the TL carries approx 4.5 - 4.7 qts depending on year and who you ask
MANY of us buy oil in the 5 quart jug
and pour in all of it with a new filter (prefill filter halfway for safety)
the small amount over indicated full has not proven troublesome to any of us,
and covers for the amount used in normal combustion/bypass
Start at full and in 7500 miles it may read at the low mark
anything under full is reduced cooling abilty
way over,, by a qt---drain out thru normal drain plug
Old Feb 3, 2012 | 10:28 AM
Type-ES's Avatar
Figured it out. Makes me feel like a dumbass. Lol
Where I park the car the street is on a angle, never really noticed it.
Old Feb 3, 2012 | 10:54 AM
01tl4tl's Avatar
that calls for an Offical... Doh!!!
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
