overfilled oil
overfilled oil
I do my oil change run the car, turn it off, check the level its right on the upper dot. If I check the oil a few days later its over filled. I've tried making sure I only get it to the line but some how it ends up overfilled. I've never had this problem before with any of my cars . Anybody else have this problem? Normal? Tips/tricks?
Oil is running from the valve cover to the pan, that takes time.
When you checked the oil a few days later was the engine hot or cold?
How far was it over?
Did you pre-fil the oil filter?
How much oil are you adding after you drain it and put a new filter on.
kill you till you die
only reliable reading is cold or left sitting 15+ minutes after running
while the TL carries approx 4.5 - 4.7 qts depending on year and who you ask
MANY of us buy oil in the 5 quart jug
and pour in all of it with a new filter (prefill filter halfway for safety)
the small amount over indicated full has not proven troublesome to any of us,
and covers for the amount used in normal combustion/bypass
Start at full and in 7500 miles it may read at the low mark
anything under full is reduced cooling abilty
way over,, by a qt---drain out thru normal drain plug
that calls for an Offical... Doh!!!
IBankMouse
06-13-2020 12:53 PM
