Oil leak
Oil leak
well ive notice oil on the ground when i park my car the last few days, and its a decent amount.i figured i got an oil leak. i looked and sure enogh its coming from the back of my engine right where the plastic cover, that covers the pistons and such is(sry i dont know the name).
anyone know how much itl be to fix, and if i should go to the dealer?
Originally Posted by fsttyms1
You mean the valve over gasket is leaking? Change it yourself. Just need to remove the upper intake manifold to get to it.
Make sure all the cylinder head cover bolts are tight first. One might have come loose. Does it look like it's leaking from the bottom of the cylinder head cover? Picture is tough to tell.
Cant really tell from that picture where its leaking. Try tightening that bolt up some to see if its loose. Also take a rag with some degreaser on it and clean that area to keep a eye on it and see better where its coming from
Originally Posted by precisionpar
Maybe even a spark plug tube seal?
Originally Posted by orgnlprankster7
maybee i bumped somthing when changing my plugs
Originally Posted by NSXNEXT
Ya know what, that's probably what it is.
you have to remove the valve cover in order to change the tube seals. I don't think it's very hard to change them once the cover is off. You can either buy the tube seals separately, or in a valve cover gasket set (ask to make sure it comes with the tube seals). Oh, and some brands sell a set for just one side. BTW, I've never done this before...
once the valve cover is removed, flip it over and the tube seals should be sitting right there. you'll notice the three tubes coming up out of the head (where the spark plugs are). Again, I haven't done this on my TL, but from experience with other Honda's...
You can check aftermarket parts stores for the gasket if you want. You should be able to pick a complete valve cover gasket set up for about $40-50.
They are part 5. (3 each side) they go where each plug hole is to keep oil from leaking out
Itch
Originally Posted by Itch71
I'm getting NGK Iridium IX this weekend. Was wondering if you think I should replace the spark plug seals at the same time? Got 100K on 99TL
Itch
Itch
IBankMouse
06-13-2020 12:53 PM
