Oil leak
Old Apr 19, 2007 | 09:59 AM
orgnlprankster7's Avatar
08 Civic SI
Oil leak
well ive notice oil on the ground when i park my car the last few days, and its a decent amount.i figured i got an oil leak. i looked and sure enogh its coming from the back of my engine right where the plastic cover, that covers the pistons and such is(sry i dont know the name).
anyone know how much itl be to fix, and if i should go to the dealer?
Old Apr 19, 2007 | 10:03 AM
fsttyms1's Avatar
You mean the valve over gasket is leaking? Change it yourself. Just need to remove the upper intake manifold to get to it.
Old Apr 19, 2007 | 10:08 AM
08 Civic SI
wow thnx for the qick reply i had no idea there was a gasket there(maybee cause ima noob) any idea what could have caused it? or can they just randomly go? ill go pick one up later
Old Apr 19, 2007 | 10:11 AM
NSXNEXT's Avatar
Make sure all the cylinder head cover bolts are tight first. One might have come loose. Does it look like it's leaking from the bottom of the cylinder head cover? Picture is tough to tell.
Old Apr 19, 2007 | 10:13 AM
08 Civic SI
lemmi go snap a better pic brb
Old Apr 19, 2007 | 10:21 AM
fsttyms1's Avatar
Is it leaking from the seam i have pointed to in yellow?
Old Apr 19, 2007 | 10:23 AM
08 Civic SI
think i should tighten that bolt? maybee i bumped somthing when changing my plugs
*wow my face looks like a potato in that pic*
NSXNEXT's Avatar
Yeah from the area he's pointing to, it looks like it's either one of the bolt holes or maybe a crack in the cylinder head cover. Looks too high to be the seal.
Old Apr 19, 2007 | 10:25 AM
NSXNEXT's Avatar
wow, really can't tell from those pictures. Do any of the bolts seem loose?
Old Apr 19, 2007 | 10:28 AM
08 Civic SI
not really, ill tighten the bolt a bit and see what happens
Old Apr 19, 2007 | 10:29 AM
NSXNEXT's Avatar
You still didn't tell us where the oil looks like it's coming from. See Kris' post #6 above.
Old Apr 19, 2007 | 10:30 AM
fsttyms1's Avatar
Cant really tell from that picture where its leaking. Try tightening that bolt up some to see if its loose. Also take a rag with some degreaser on it and clean that area to keep a eye on it and see better where its coming from
Old Apr 19, 2007 | 10:43 AM
precisionpar's Avatar
Precision1
Could be one of those valve cover grommets. Maybe even a spark plug tube seal?
Old Apr 19, 2007 | 10:48 AM
NSXNEXT's Avatar
Ya know what, that's probably what it is.
Old Apr 19, 2007 | 10:53 AM
08 Civic SI
ok now im gonna have to ask.... whats a spark plug tube seal cause i just looked and took mor epics and i cant find the source
Old Apr 19, 2007 | 10:57 AM
08 Civic SI
it does seem to be coming from around the coils..
oh and as per fsttyms post it doesnt seem to be around the egdes, i asume thats where the gasket it
Old Apr 19, 2007 | 11:29 AM
Precision1
you have to remove the valve cover in order to change the tube seals. I don't think it's very hard to change them once the cover is off. You can either buy the tube seals separately, or in a valve cover gasket set (ask to make sure it comes with the tube seals). Oh, and some brands sell a set for just one side. BTW, I've never done this before...
Old Apr 19, 2007 | 11:34 AM
08 Civic SI
can you describe where the tube seal is located? also acura oem parts says price is 150$ for the gasket set, is that right
Old Apr 19, 2007 | 11:49 AM
Precision1
once the valve cover is removed, flip it over and the tube seals should be sitting right there. you'll notice the three tubes coming up out of the head (where the spark plugs are). Again, I haven't done this on my TL, but from experience with other Honda's...
You can check aftermarket parts stores for the gasket if you want. You should be able to pick a complete valve cover gasket set up for about $40-50.
Old Apr 19, 2007 | 11:55 AM
08 Civic SI
thx
Old Apr 19, 2007 | 11:59 AM
fsttyms1's Avatar
They are part 5. (3 each side) they go where each plug hole is to keep oil from leaking out
Old Apr 19, 2007 | 12:57 PM
NSXNEXT's Avatar
I replaced mine when I powdercoated my cylinder head covers. I seem to remember they were a bitch to remove and put back on.
Old May 17, 2007 | 06:37 PM
Itch71's Avatar
I'm getting NGK Iridium IX this weekend. Was wondering if you think I should replace the spark plug seals at the same time? Got 100K on 99TL
Itch
Old May 17, 2007 | 07:03 PM
Precision1
I'd only replace them if they were leaking.
Old May 17, 2007 | 08:36 PM
fsttyms1's Avatar
Itch
Only if leaking.
Old May 18, 2007 | 04:44 AM
Itch71's Avatar
Thanks guys!
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
