Misfire problem Help!
Old Apr 5, 2010 | 11:29 PM
fresh00tlp's Avatar
9th Gear
I have this very annoying mifire issue. Its a 00' TL with 283K on the clock. Ive been dealing with this or a few weeks and have started to notice a pattern. It will not miss when its cold. After driving around town on a warm day, I shut it off, try to restart it, it wil start and miss badly, and the cel flashes. I have to drive it or rev the hell out of it before it clears up. Sometime it will not start at all unless I hit it with a shot of ether or carb cleaner.
Codes are misfire 1-6, random cylinder misfire, and a manufacturer specific code. I cant figure this out and its buggin the hell out of me, and its kinda embarassing ridin around with a freind, having them compliment you on your car....then it wont start an runs like ass. Any deas?
Old Apr 6, 2010 | 10:11 AM
RACINGHART03's Avatar
There is a service bulletin for this. ECM replacement and fuel pressure regulator.
Old Apr 6, 2010 | 12:03 PM
tunene25's Avatar
mine got that same problem 2 sometimes it does it sometimes not when i took it to autozone they say the oxygen sensor was bad and two of the coils was probably bad could u put the link racinghart03?
Old Apr 6, 2010 | 01:33 PM
fsttyms1's Avatar
Our cars commonly have coil packs go bad. Buy one and swap it around to see if it clears up the issue. (for more info search the forum, there is plenty) If you havent already put new plugs in it. I would also recommend seafoaming the engine and adding it to the fuel as well to clean the injectors. If you continue to have it you may have other problems that we can get into then.
Old Apr 6, 2010 | 10:24 PM
fresh00tlp's Avatar
9th Gear
I have be through 3 cans of seafoam in the last few weeks. Not so sure its a coil pack because it misfires random cylinders, the scanner says its every one of them. It deinitely seems like a fuel related issue. Im gonna try that fpr and see if it does the trick. ECM replacement? Post a link to the TSB please....thanks for the help, it woulnt start on 4 different occasions today while I was doing things around town.
Old Apr 7, 2010 | 07:45 PM
silvernight's Avatar
Sylvia aka SilverNight
i need help 2000 tl
I was recently havin these stalling problem and 6 codes came up to change all my ignition coil so i did and while doin them i also replaced my spark plugs. i did all that 3 days ago and today after driving for 30min i stop for lunch i came out to start my car and the RPM needle went back under 1 and started to stall but did not cut off. Is there anything else i can do to resolve this problem?????? Please help
__________________
Old Apr 7, 2010 | 08:29 PM
fsttyms1's Avatar
That is VERY common on these cars and is usually just 1 coilpack.
Old Apr 7, 2010 | 09:24 PM
fresh00tlp's Avatar
9th Gear
Well how can I tell which one if the scanner tells me its all of them?
Old Apr 7, 2010 | 10:40 PM
fsttyms1's Avatar
A good scanner will usually put the one thats misfiring first like P0303 then followed by the rest in order. If not the best way is to buy 1 new coil pack start on one of the cyls and replace the stock one with the new one. Reset the ECU (by pulling clock backup fuse if you dont have a code reader) and go for a drive. If it comes back put the stock one back on and repeat procedure to next cyl. Repeat till you find the bad one.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
kencepeda
Sep 26, 2015 05:13 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
