Loud Knock when Reverse Gear engaged:
Old Apr 21, 2011 | 12:23 AM
the game is thick's Avatar
POWERLINE
Hello all, I have a 1999 TL-P. I've been reading a ton of threads on tranny problems with this car and I just want to verify what my issue is. I read in the sticky about transmission problems that when putting the car in drive or reverse it can be a normal issue with this car to hear a mechanical sound and should be nothing to worry about. To be more specific it sounds like a loud clunk/knock each time it goes in reverse only. Is this normal? Thanks in advance
Old Apr 21, 2011 | 12:47 AM
Karanx7's Avatar
Unregistered Member
No, it doesn't sound normal. They say "mechanical noise" to avoid everyone assuming their tranny is dead.
But a clunking noise is different I think. I've never experienced any clunking noise. If it's just a "thud" it could be a broken engine mount, but a clunk/knock sounds like a problem
Then again if you have a 99, you're less likely to have tranny issues. How's your fluid? Dark brown/burnt sugar smell is bad.
Did you ever have your transmission replaced? Blue bolts on the tranny case mean that the dealer has replaced it. Oil jet outside means pre 2005.
Old Apr 21, 2011 | 01:31 AM
POWERLINE
thanks karanx. I got the car for an amazing deal. It Had blown head gaskets that i recently changed along with other issues. I did notice some faded black permanent marker writing on the transmission although i am unsure if the previous owned changed it. it has 160,xxx miles and the engine is smooth since after i did the overhaul aside from the loud noise when engaged in reverse. ill check the heads of the bolts tomorrow to see if they are blue, what should i look for on the oil jets outside?
Old Apr 21, 2011 | 01:55 AM
01tl4tl's Avatar
suspect the motor mounts if you are not having trans slippage under hard throttle
the front and rear mounts are fluid filled and most years-vac boosted!
so a broken mount will leak a weird oil down it and maybe onto the floor
also causes mystery vac leak and engine miss
oil jet kit- on top of trans-look in front of the brake lines for large bolt with ATF cast on it-if there you have internal kit- post 05 replacement trans with new case design
BUT
Im didnt think 4 speeds were part of the oil jet kit recall? 99 experts??
99s 4 speed is much more reliable than later years with 5 speed too
Old Apr 22, 2011 | 01:23 PM
POWERLINE
checked it out and i didnt find a oil jet kit or blue bolts. But i did notice that when i put it in reverse once last night it didnt make a noise. ill recheck the front and real mount, although it idles fine. I wouldnt be surprised if the previous owner changed the transmission sometime on this 12 year old car with 160k
Old Apr 22, 2011 | 03:55 PM
fsttyms1's Avatar
my guess would be the mounts.
Old Apr 22, 2011 | 04:19 PM
01tl4tl's Avatar
the mounts condition -the bolt heads--will show if the trans has been out before
the engine miss may not apply to your car - if not `vac boosted` mounts
Old Apr 22, 2011 | 08:53 PM
POWERLINE
ill do a better diagnosis and see if i can come up with an answer. thanks for the input.
Old Apr 22, 2011 | 11:56 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
Front motor mount. Mine does the same thing.
Old Apr 23, 2011 | 01:50 AM
01tl4tl's Avatar
forgot this car is a 99--all bets are off for oil jet kit and blue bolts etc
4 speeds are not part of that whole thing
Old Jul 20, 2011 | 05:40 AM
POWERLINE
figured it out. i replaced the cv axle and it went away.
Old Jul 20, 2011 | 01:12 PM
57 Handyman's Avatar
My son's 99TL just went thru a trans rebuild and makes a klunk sound upon initial startup. I am wondering if old/loose CV joints are the culprit. How did you determine the CV axles were bad? The axle boots look to be okay and not torn.
Like yours, his car also has high mileage...120K and he is not original owner...so there is a little unknown history.
Old Jul 21, 2011 | 03:29 AM
POWERLINE
handyman, i changed out the drivers side cv axle because it was causing vibration under acceleration. it turned out it fixed the know too!
Old Jul 21, 2011 | 12:01 PM
01tl4tl's Avatar
an alignment shop can ck the axles for you
Old Sep 8, 2011 | 08:35 AM
uleiro's Avatar
I have a 99 tl-p. And Im getting the Same clucking noise when switching to reverse I've changed out all mounts and driver side axle. Did you replace both axles?
Old Sep 8, 2011 | 07:27 PM
yeedatoy's Avatar
kill you till you die
This doesn't make sense to me. are you sure the noise doesn't change with temperature. I cant see the CV making a loud knock from putting the car in reverse. Mine does that upon first start up on cooler days, and not at all on warmer days.
Old Sep 8, 2011 | 09:43 PM
01tl4tl's Avatar
the right cv would make more noise into reverse- with the action of motor motion and trans torque
Old Sep 14, 2012 | 02:24 PM
Chevelle66's Avatar
Necro-bump....
I have a 2000 tl with a rebuilt tranny with about 600 miles on it. I experience a clunk when putting it into reverse when I am Parked up hill. Not a slight incline, but parked in my friends driveway with a decent slant. Only time I get a clunk. Also, when going from reverse to D5, there seems to be a delay before it seems to engage.
Old Sep 14, 2012 | 08:21 PM
smartypants's Avatar
I just had my 99's tranny rebuilt and one thing I immediately noticed was when I backed out first thing in the morning, the great "THUNK" is gone.
I suspect you have the same issue.
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
DerrickW
Nov 15, 2015 05:52 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
TL14
Sep 24, 2015 04:37 PM
STL TL-S
Sep 23, 2015 08:52 PM
