Left and Right Signal HELP
Old Apr 3, 2013 | 09:26 AM
tjkazai's Avatar
2002 Acura TL
When turning left or right,
sometimes the signal light cuts off at random times...
Can anyone help?
Old Apr 3, 2013 | 09:28 AM
DanTL-S's Avatar
How's your connections? If the light blinks fast when it's working it's just a bad bulb.
Old Apr 3, 2013 | 05:20 PM
3.2TLc's Avatar
Yeah, check the bulbs and connections first.
It could be that your flasher relay is going bad ?
Old Apr 7, 2013 | 07:45 PM
tjkazai's Avatar
2002 Acura TL
It used to be working fine last week, then suddenly it became weaker...
I turn left for example it works for a couple seconds and it cuts off and I'd have to lift the lever back up and put it back down to signal
Where can I check the connections or that flasher relay you were talking about?
Old Apr 8, 2013 | 07:00 AM
3.2TLc's Avatar
So, both sides of the turn signals are affected when attempting to activate the switch ?
It could possibly be the stalk switch itself going bad. Does your 4 way emergency flashers work when their switch is turned on ? If the turn signal lamps all work and you hear the relay under the driver's side dash clicking, then I'd look at the stalk switch.
But, if not.....then check all the turn signal lamp's sockets, wiring connections and grounds for anything that may cause a problem. If all the lamps check out, then look under the dash for the flasher relay for the turn signals. If good, it should click when the switch is turned on.
us285126
Oct 2, 2015 02:03 PM
hashbrown
Sep 29, 2015 12:13 PM
rhdune16
Sep 28, 2015 11:31 AM
h22lude
Sep 27, 2015 06:22 PM
ripit
Sep 26, 2015 06:19 PM
