Left and Right Signal HELP
I turn left for example it works for a couple seconds and it cuts off and I'd have to lift the lever back up and put it back down to signal
Where can I check the connections or that flasher relay you were talking about?
So, both sides of the turn signals are affected when attempting to activate the switch ?
It could possibly be the stalk switch itself going bad. Does your 4 way emergency flashers work when their switch is turned on ? If the turn signal lamps all work and you hear the relay under the driver's side dash clicking, then I'd look at the stalk switch.
But, if not.....then check all the turn signal lamp's sockets, wiring connections and grounds for anything that may cause a problem. If all the lamps check out, then look under the dash for the flasher relay for the turn signals. If good, it should click when the switch is turned on.
us285126
Oct 2, 2015 02:03 PM
ripit
Sep 26, 2015 06:19 PM
